So the k7 pro will be 500 USD+
It better be punching way above its price point
Thank you for providing 3 gain options. That's probably the most important function for spreading out the gain for power requirements on different headphones. Does this also imply that power output will be pretty high up for really demanding headphones? I hope so.Here is the more detail of K7/K7Pro, they share the same design but just the DAC is different, ONE QUESTION, do you want USB B or TYPE C on the back? Note, there will be another TYPE C on the right side of the box>>>https://www.facebook.com/chung.james.92/posts/2972176889557027
Hi,Are you planing to include a remote controll ?
Its massivThe size comparison of K3/K5Pro/K7, be noted that the K7 is just a simple mock-up but not prototype. just to show how big it will be.
Like the drop. Not like SP200.Its massiv
Will it be true balanced ? or like other thx amp just working with one dac chip ? In that case will the non balanced output put out less power ? Like the drop 789. Or will it put out the same power balanced and unbalanced like the smsl sp200 ?
Can we have measurements of the sizeThe size comparison of K3/K5Pro/K7, be noted that the K7 is just a simple mock-up but not prototype. just to show how big it will be.
Yes it will be more expensive than that. Your budget is right at the drop 789 amp... you won't find a thx amp+dac ar this price :/My max budget is $300. This seems expensive.
