In this case no balanced output for K9? :'(This might be a good suggestion.
FiiO K7/K7BT Desktop DAC&Headphone AMP Discussion | XLR Balance | Dual THX AAA | Xmos | ...
FiiO Willson
Sponsor: FiiO
I know, but hard to keep enough replacement parts, while not enough AKM4499 available.
We have a lot of experience and in fact we do not use up all of our stock, but rather leave a quantity available for repair.
FiiO Willson
Sponsor: FiiO
Balanced output is essential.In this case no balanced output for K9? :'(
I thought 2xAKM4499 is technically mandatory to balanced output. Why need 2 then?Balanced output is essential.
FiiO Willson
Sponsor: FiiO
In fact, 1 can have a balanced output. But with 2, the outputs can be independent and the sound quality and output power will be higher.
Thank you. I'll choose the double version, when available.In fact, 1 can have a balanced output. But with 2, the outputs can be independent and the sound quality and output power will be higher.
Baten
- Sep 13, 2012
A single chip is -fully- capable of balanced, two chips (dual mono) just has slightly better specs; on paper..I thought 2xAKM4499 is technically mandatory to balanced output. Why need 2 then?
The AKM4499 is a quad channel chip. The D90 DAC splits the 4 channels into a pair of two channels each to achieve its balanced output.I thought 2xAKM4499 is technically mandatory to balanced output. Why need 2 then?
Dual AKM4499 in the K9 pro would mean each chip would have its complete 4 channels available for each end of the balanced output.
omegaorgun
Previously known as FireLion
Any news on release date?
Follow this topic:Any news on release date?
https://www.head-fi.org/threads/fii...,xlr-rca-4-4-optical-coaxial-interface.952664
omegaorgun
@FiiO Willson I do like Burr Brown too, they often get overlooked, but companies like IFI use them a lot.
FiiO Willson
Sponsor: FiiO
Almost all of IFI's products use Burr Brown chips; however, we have no plans to introduce them for the time being, thank you very much for your support!@FiiO Willson I do like Burr Brown too, they often get overlooked, but companies like IFI use them a lot.
- Mar 20, 2013
Affirmative
Stay updated on iFi audio at their sponsor profile on Head-Fi.
it looks like the K7 won’t go beyond the drawing board…
ticoss
- Aug 12, 2004
The K7 is well planned for this year
https://fb.watch/ej-DBxnF6w/
Since its launch, the FiiO K5 Pro has been welcomed by users with its compact size, robust output power and competitive price. In fact, our users have kept urging us to increase the balanced output. However, due to chip supply shortage in the past two years, it took us great effort to replace the DAC chip. So we had less time for new product development.
Fortunately, we made it this year. The K7 is expected to enter the market in September. Although the housing is the same as the K5 Pro, the inner structure has been greatly adjusted. The headphone output is a four-way true balanced amplifier structure. In addition, we have also designed something new for the appearance, esp. the light effects.
I would like to show several light effects of turning on. See if you like them or not.
The first design is a loop of iridescent lights showing up when the K7 turns on, and then the light will turn blue.
