FiiO K9 Pro Hi-Fi DeskDop DAC&Bluetooth&Amplifier,XLR/RCA/4.4/Optical/Coaxial interface
Jan 19, 2021 at 4:52 AM Thread Starter Post #1 of 2,279
FiiO Willson
Sponsor: FiiO
China
2021.10.14 Update
Dear friends, K9 Pro is now available, you need to buy can find a local agent, or order online, the following is the product introduction information
Here is the article I posted earlier for communication with you:
Hello Everyone
I'm Willson, Product Manager of FiiO, and I'm here to introduce you to a new product:
FiiO K9 Pro Hi-Fi DeskDop DAC&Bluetooth&Amplifier:
SPEC:
1,Linear power supply, supports 115V/230V power supply.
2, AK4499 DAC,4.4mm Balance Output.
3, Support MQA
4, Customised THAAA AMP
5,USB DAC support up to 768kHz/32b decoding (DSD512 support)
6,Optical/Coaxial decoding supports up to 96k/192k sample rates respectively (DOP64 supported)
7,Bluetooth with the new QCC51xx series, support LDAC/aptX adaptive/AAC/SBC and other coding formats, support BLE control
8,Hi-END class parameters and configuration
Input Interface:
1,Digital inputs: BT/Coaxial/Optical/USB in
2,Analog input: 4.4mm/Line in/
Output Interface:
1,Line output
2,Balanced out XLR*2
3,XLR4 output
4,6.35mm/4.4mm output
Other:
1,Multi-state selection and indication
2,APP Control
3,Adjustable volume knob
4,The price will remain the same as usual and will always be a pleasant surprise for everyone.
5,Limited sales expected in April
Note:
1,Because of the AKM fire, the number of AK4499 chips is limited, so the number of K9Pros is also limited
2,A lower priced dual DAC version of the ES90xx will be available around August 2021
More information will be added gradually, if you are interested please discuss with us below, thanks.
Jan 19, 2021 at 5:09 AM Post #2 of 2,279
My first interest is how many W per channel does it have on SE & BAL & maybe the most important question is how many units will come with the AKM chip ? As far as price goes I'll take my guess and say it's around 650 USD
Jan 19, 2021 at 6:07 AM Post #3 of 2,279
Does it come with a remote volume control?
Jan 19, 2021 at 8:53 AM Post #4 of 2,279
Is the volume knob surrunded by colour light to indicate the sampling frequency?
Jan 19, 2021 at 8:27 PM Post #5 of 2,279
Hi,
1,The SE output power should be greater than 1.5w, the balanced output power we are trying to debug, we hope to bring you better data.
2,Because of the shortage of AKM chips, there will only one in the K9Pro.
Jan 20, 2021 at 8:20 PM Post #9 of 2,279
In K5 pro volume knob backlight is too bright especially when listen at night.
The K9 Pro will have an indicator light switch in the APP, so you can choose to turn it off if you feel the light is too bright
This may be more friendly
Jan 21, 2021 at 2:27 AM Post #11 of 2,279
is it noise free for ultra sensitive IEMs? high low gain?
Can it be used as Dac only?(volume is bypassed)
The noise we are debugging, it is more difficult but I think it will be perfect in the end.
Of course the K9 Pro can be used as a standalone DAC, which is a must
Jan 21, 2021 at 8:19 PM Post #14 of 2,279
What will be the main difference between AKM4499 and Dual ESS versions?
I'm thinking for sound quality, power, noise, not technical differences.
Dual ESS versions hasn't started yet.
But there are definitely functional differences,Probably cheaper in price.
I can't tell you exactly now because there are many variable things.
