How long is K5 Pro power cord?
Dear friend,
About 0.5+1.5m.
Best regards
Dear friend,@FiiO is the amplifier in the K5 Pro exactly the same as the old K5 or has it been tweaked/modified?
I have a couple questions about K5 Pro's line-out.
Does the line-out switch off if the headphones are plugged in?
Does the volume control change the level of the line-out, or is it a fixed output line-out?
Dear friend,Hi @FiiO I already have a pretty decent amplifier, so can I connect the K5 Pro via RCA to my amplifier and use the K5 PRO as a DAC only? Thank you!
Dear friend,Hi @FiiO, please tell me you didn't forget an option to switch off lighting off on the knob. When Im watching movie or listening to music at dark room the last thing I need is light blasting my eyes. No light off is deal breaker for me. I find the idea of different light color on knob silly anyway its distracting, simple small diodes (which can be easy covered with plaster would be just fine)
Key features of the FiiO K5 Pro include:
High-performance DAC: AK4493
USB decoding chip:XMOS XUF208
Specially designed audio architecture: second order LPF+analog volume adjustment + voltage amplification +current drive
Variety of inputs: coaxial/optical/RCA line-in
Variety of outputs:6.35mm (1/4 in.) headphone out/RCA line-out
Gain control: low, medium, and high gain
USB DAC:768K/32Bitand native DSD decoding
RGB sampling rate indicator: blue/green/yellow
Extremely powerful, easily powers any full-size headphones
Available in Black
To find out more about the K5 Pro, please visit the product page on https://www.fiio.com/K5pro and have an visual insight of the K5 Pro via YouTube at:
The global dispatch of the K5 Pro begins today and as usual we will share a daily delivery updates on a separate post. If you are interested to purchase the K5 Pro, check with our local sales agent (at https://www.fiio.com/wheretobuy) or FiiO Aliexpress store(at https://www.aliexpress.com/item/4000122939110.html) for its availability.
Finally, to celebrate its global release, we are giving out two K5 pro to two lucky fans on Head-fi at: Click here. Don't miss the chance!
Best Regards
FiiO Electronics Technology Co., Ltd
Dear friend,Can I connect a Sony NW-wm1A vía the fiio LS27 cable? Or I need the Sony one?
Dear friend,
No because the usb port of the K5 is square one.
Best regards
Dear friend,Thanks!
But I can use the Sony WMC-NWH10 cable and connect it that way? Does it work with the Sony NW-WM1A?
