@FiiO
I don't knoiw what is wrong with my K1 on my Windows PC and foobar2000 it works fine, but I tried on my smartphones (reason why I bought) and it doesn't work:
http://www.head-fi.org/t/704065/usb-audio-recorder-pro-uapp-24-and-32-bit-playback-ubiquitous-usb-audio-support-for-android/480#post_12114445
I tried other music apps, but the music stucks and does not play properly. Like in the link above my smartphones fully USB audio compatible and even with 3rd party USB audio apps, the K1 doesn't work.
What is wrong? Like I said, since the FiiO K1 needs only 36mA the power output in both phones can't be the problem, since I can use other USB DAC/AMPs with more power needs (50mA) which works fine.
Btw. the FiiO K1 is perfect for multiple driver IEMs, I measured with low impedance and 8 driver IEM and really well straigt flat line! (the small bass roll off is from my sound card, not from the FiiO K1!):
/EDIT
It seems I understand something wrong, or this is new interpretation:
FiiO specs of the K1:
MAX output current 35.93mA
On the box from the box small a information "
Input: USB powered 5V with 150mA" if it's really 150mA required this will never work with any phone, damn that's sad
