FiiO Hybrid IEMs Discussion & Impressions Thread
Dec 9, 2024 at 5:10 AM Post #3,001 of 3,025
If you're having constant cutouts, then the answer is yes. But, if you have not had any incidents so far, then I would just not worry about it. Look at the male connector with a magnifier, you may be able to expand it a little more if needed with a plier — conditioned to your skills in doing so.
If you are unsure and it is easy for you to return, then just do it and avoid a headache down the road. But that's only my opinion. I hope the manufacturer can chime in before your return period ends.
Good luck.
For now I have no signal interruptions, but I am worried that in the long run there may be interruptions and contact issues.
Let's see what @FiiO answers, regarding the possibility of returning the FH19 due to this defect.
Dec 10, 2024 at 9:13 AM Post #3,002 of 3,025
I just received the FH19 and noticed that the left channel MMCX connector is very loose and spins too easily, it practically can't stay still. Do you think this is a defect that would justify a return? @FiiO
EDIT: I found this video, maybe it's a solvable problem
EDIT 2: I have tried many times but it is impossible to do it without risking damaging the connector. And now what do we do? @FiiO
Had the same issue with my FA9, did not justify for a repair/return back then
Dec 10, 2024 at 10:10 AM Post #3,004 of 3,025
If @FiiO could guarantee that the very loose mmcx connector won't cause contact issues and signal interruptions over time, I'd be satisfied.
In my personal experience, people who buy FiiO products upgrade often and fast. Probably you'll no longer own the IEM at the point where this happens.
But if, chances are it could cause issue. It will not get tighter but probably even more loose over time
Dec 10, 2024 at 10:51 AM Post #3,006 of 3,025
I had the same problem with the FA9, the first pair were tight while the second pair were loose, in general I prefer the tight fit but if they are a little loose it's fine too, the thing I hate is that one hook is tight and the other loose... in this case I get obsessive compulsive disorder
The same was on my FA9, only one side. I assume cheap MMCX connectors (What a surprise, who would have guessed that :D)
Dec 10, 2024 at 1:29 PM Post #3,008 of 3,025
... the thing I hate is that one hook is tight and the other loose... in this case I get obsessive compulsive disorder
Ohh, you just described the world I live in. :smile:
I'm kidding. As long as I don't have cutouts, the MMCX connector can rotate as loosely as can be, and I don't typically mind as well. Also, I confirm by applying a moderate traction without fully disconnecting the ends. That certainly helps minimizing my OCD.
By the way, my right FH7S has always been that way with the UTWS5. I do have cutouts these days but because another (sweating) reasons. And guess what? Warranty is also due. :hourglass_flowing_sand:
At least FiiO cables are good. I purchased a fancy Sony cable once and I could not even get a connection with the FH9 in the right piece. Cable immediately worked on a little Shure I have here. It seems that the expanded connectors are not only on the male side, but also in the female ends as well. At least, based on what I observed with my gear.
Dec 10, 2024 at 10:55 PM Post #3,009 of 3,025
Dear friend,
Hi, if the loose MMCX connector does not affect the sound, you don't need to be too worried. But if it affect your normal usage, you could try to contact your seller for helps first. If the seller fails to help, please contact support@fiio.com with the receipt attached. Thanks in advance!
Best regards
Dec 12, 2024 at 5:16 AM Post #3,010 of 3,025
Dear friend,
Best regards
Thanks for your reply. As I said, for now I have no problem, my concern is that over time there might be connector contact issues affecting the sound. I hope I'm lucky...
Dec 20, 2024 at 9:28 AM Post #3,011 of 3,025
Well, that's so disappointing. I bought the FH9 + BTR17 combo as a present to myself for getting a promotion at work.
The FH9 are built like a tank no doubt. But having spent many hours working my way through my entire tip collection i had no choice but to send them back.
They're just too big & heavy to stay in my ears for more than a couple minutes. Even when i think they're in there, after 10 minutes i can feel them on the verge of falling out. I think the almost 13g of weight is just too much when reliant on the tips alone for retention.
I adore the sound they made. Just stunning when driven with the BTR17 + Tidal music.
Keeping the BTR17 as that's a lovely unit but bye bye to the FH9's. Back to using my FH5's which do fit nicely.
Dec 27, 2024 at 6:59 PM Post #3,012 of 3,025
I only ever used large “Sonic Foam” tips with my FH9’s. https://www.sonicfoam.com/ Now I use them again with the FH19. Haven’t looked back.
Mar 24, 2025 at 10:52 AM Post #3,014 of 3,025
Them FH19 arrived I'm really enjoying the green filter paired with my Onix XM5 Overture they sound phenomenal for the money I paid in the AliX sale they are an bargain. I will say it was an absolute mission to get them out of the awful plastic tray. I guess foam must be expensive
Im really pleased they sound different to the FH9 which I also love they won't be retired anytime soon.
Mar 24, 2025 at 11:39 AM Post #3,015 of 3,025
Yeah the FH19 are really nice and sometimes I think to myself that damn I really need that bass in my life. But the unique way Fiio smooths out the mids always gets to me.
While that colouration makes so nice for vocals sometimes a electronic track comes in and it feels like a big glaring hole between the sharp bass and treble.
Other than that one nitpick damn this is a good iem where Fiio was willing to take risks and it really paid off.
