My full review of the F9 Pro: http://kopfhoerer-lounge.blogspot.com/2018/01/fiio-f9-pro-review.html#more
FiiO F9, F9Pro-Detachable MMCX connector,Hi-Res Audio Certified,2.5mm TRRS/3.5mm audio cable
queerquirks
- Jan 13, 2012
Are the ear tips different in dimensions for the same size.
Eg For my ears, my usage for Balanced tips (M) = Bassy Tips (L)
bk123
- Nov 15, 2015
Just visit this page:https://www.head-fi.org/threads/fii...ed-2-5mmtrrs-3-5mm-audio-cable.855281/page-81Are the ear tips different in dimensions for the same size.
to get the dimensions of eartips, posted by "FIIO".
George Taylor
I really don't want to go back through the close to 90 pages to find out about this, so I'll ask instead. Has anyone mentioned burn in with the Pros? Last night I hooked them up to my system and I swear, the highs had subsided to a much more listenable level for me. It's not like I've been using them constantly and just gotten used to them, I was listening to my HE560's before this. That said, they sounded really glorious. Hoping whatever has happened to them remains in play.
Dobrescu George
Reviewer: AudiophileHeaven
I haven't noticed any changes so far, but as always, YMMV
Researcher
use search up there on the page, then
George Taylor
Ok, think I have this figured out now. And you'll have to forgive me, because IEMs are not my strength. The difference is simply that I didn't have them seated deep enough into my ear canals. That is what's making the difference between me thinking they sound amazing in one sitting, and then trying to figure out where this freaking treble peakiness is coming from. I moved down to the smallest tips and that's helped a lot. I'm not a small person, so I figured my ear canals must be large too. Guess not.
Dobrescu George
That actually makes a lot of sense, changing the depth of insertion will affect the signature of a IEM.
I prefer F9 and F9Pro with deep insertion, as much as their body / tip provides, since that also hits the sweet spot of comfort for me.
PlantsmanTX
All the tips of the same size should be the same diameter.Are the ear tips different in dimensions for the same size.
Dobrescu George
That is what I tought as well. Some of them have the inner part a tad thicker and they might provide comfort differently for some ears, but the actual size should be the similar.
George Taylor
Yeah, with me it's more about "getting a proper seal" with the right size. Like I said, the difference in sound is night & day if I get it wrong.That is what I tought as well. Some of them have the inner part a tad thicker and they might provide comfort differently for some ears, but the actual size should be the similar.
New Fiio Owner
I am approaching 50 and only recently realised I have small ear canals in spite of having ears like the FA Cup.
I replaced all of my tips on various earphones with Size Small Memory Foam and the sound difference is amazing. I now have a tight seal with lots of Bass, trust me, if you do not have the right sized tips you will never have the right sound.
New Fiio Owner
Goodbye all, I have asked Brooko to delete all of my posts and close my profile.
Edit: On the advice of Brooko I will take a Chill Pill and consider returning.
Thanks to everyone who has helped me with their valuable hints and advice.
Hi
Thanks for the review. In it, you compared the F9 Pro to the Fidue A73. Do you have knowledge of the A83? If so, how does it compare to the FiiO?
Regards
Darren
chupacabra314
- Oct 8, 2014
Hi
Regards
Darren
My 2 cents, bearing in mind it’s been a few years since I had the a83 and folks much more experienced than me swear by them. The short version - I prefer the F9Pro on every parameter except for the 3.5mm cable.
The long version: Bass on the F9P extends further and is slighty more in quantity with better balance between mid and subbass. I also find it better textured despite the higher quantity. IIRC the 83 had a significant dip in the lower treble making it sound dry and without sparkle. Mids are better on the 83 if you compare with the Fiio bass tips but similar with the others. Fit and comfort go to the F9 hands down.
