liamstrain
Member of the Trade: The Audio Guild
- Sep 18, 2011
Do you need a DAC as well as the amp?
With a max budget of 200 and a desire for accurate sound, maybe look at the Audio-GD Sparrow - version B fits comfortably in your budget - has a DAC/AMP and will way outperform the FiiO E9. The Yulong Crystal DA would also be a good choice.
For only slightly more - and much better sound, if you do not need a DAC, is to get the M-Stage. This is really the best price/performance of any non-tube budget amp out there. If you do need the DAC, and can stretch the budget just a bit, the Audio-GD NFB-12 would be a great option too - better than the Sparrow (it is only 200, but shipping will tip you past your budget).
If you decide to go with the AKG - do NOT get the E9. It does a poor job damping the bass, and sounds very distorted with that headphone. It's probably OK with others - but I think there are better options for similar money.
