Fiio E9, enough for the HD 800's?
- Thread starter Lan647
- Mar 20, 2010
The K70x is pretty damn bright with the E9. The E9 doesn't mask the brightness of the K70x.
- Mar 20, 2010
The E9 stays pretty true to the source and headphone, so if you find the K70X too bright, the E9 isn't gonna hide this fact. You will get pretty much the idea of the HD800s signature with little to no coloration.
I personally found the K701 too bright for my taste with the E9. It was fed with plenty of power, but the brightness just didn't do it for me. Not the fault of the E9. I just didn't like the K701 for music.
Lan647
But I have personally compared the k701 and the HD 800 and the k 701 is significantly brighter.
soundaddicted
- Nov 17, 2010
You could try the HA-160D, im sure its a good match for the 800's like their earlier amp version.
winma
- Apr 6, 2010
WAAAAAAAAAAAAAAAAAY to expensive.
Im sure is worth it.
A nice piece of gear specially when you have a good budget.
Riku540
- Sep 30, 2005
Except that's more than 8x the price of the E9 which kinda steps on the whole point of this thread...
winma
- Apr 6, 2010
Got your point guys, its just hard to pass over on this one.
BTW, is portability a must? considering that you like to listen music in a portable mode.
Lan647
Talking to me?
Depends on how you define "portable", but yes I don't want to have the feeling of being "stranded" inside my house in my living room. No matter how expensive, heavy or leaky a headphone is, it's still a headphone.
Lan647
When my budget has recovered, I wont be buying an SS amp, I'll probably buy a high-end tube amp.
Lan647
If not, since the E9 is told to be very transparent, can anyone with experience using the 800 with a transparent headphone amp tell me EXACTLY how that sounds? Would help me a lot...
