Fiio E17k Alpen 2
Mar 12, 2017 at 7:51 PM Post #466 of 516
Pairs quite well - especially if you prefer a more natural rise in the upper mid-range (use no front filter), but don't like the treble which results from not using a front filter.  You can then knock it down to a better level with the E17K tone controls.
Mar 12, 2017 at 8:13 PM Post #468 of 516
Again - it definitely "works".  I prefer the E17K because of the tone controls - but the Q1 is a good little amplifier with an equally good DAC.
Mar 13, 2017 at 4:20 AM Post #470 of 516
I haven't noticed any hiss - but I find generally that I can't hear hiss because of my tinnitus.  Perhaps ask in the FLC8S thread and see if anyone else has tried the combo?
Mar 27, 2017 at 11:38 PM Post #472 of 516
Hi everyone, just wondering if I can connect the E17K to an iPhone 6 as a DAC just using the L9 lightning cable from Fiio? or do I go through the apple camera kit??
Dear beemerm635,
The E17K was designed chiefly as a USB DAC for computers;  it has not been purposely designed for use with smartphones and we make no claim that it would work.  For USB decoding from smartphones, you may try turning off USB charging on and then connecting it to your iPhone 6 with a genuine Apple Lightning->USB adapter (Camera Connection Kit) (CCK). The L9 is for the iPod so it is not compatible with the iPhone 6.
Best regards
Apr 3, 2017 at 12:18 AM Post #473 of 516
 Hi guys!
Very soon I will have my Fiio e17k Alpen 2 connected to my Fiio K5. I will use this kit as an exclusive DAC from my PC (windows 10). The e17k will be connected to the K5 through the main dock. (Micro usb)
 I know there is a playback limitation on e17k using the micro usb connection: 96 kHz / 32 bit.
My question is: what happens when I try to play a song with 192 hkz / 24 bit? Will not work? Will it play normally, but with a downgrade in sample rate? Any risk to damage the device try playback a song with 192 hkz sample rate?
Thanks a lot for the help!
Apr 5, 2017 at 3:28 AM Post #474 of 516
   Hi guys!
Dear Reboot,
If you are choosing the ASIO as output, the player would not be able to play your song with 192kHz/24bit. But if you choose DS as output, the sampling rate is depending on the settings in sound device.
Best regards
Apr 13, 2017 at 9:57 PM Post #475 of 516
Hi, I'm a little clumsy with the connections...
I have the 17k and musical fidelity v90 hpa
my idea is to have the fiio as dac and MF as amp ... can be done?
What are the correct connections?
regards
Apr 13, 2017 at 11:03 PM Post #476 of 516
regards
I would think that LO to the amp would be the best solution. Lo to dual RCA cable is your best best i think. What would you use as source and how would you connect it?
Apr 14, 2017 at 3:33 AM Post #477 of 516
hi superuser1, I use the pc as a source, now I have the Fiio connected by usb, I like the sound more than with the MF
Apr 15, 2017 at 11:37 AM Post #478 of 516
Well, it seems that I have achieved, now I use the fiio as a dac and the MF as an amplifier.
The only bad thing now I can not control the bass and treble in the fiio ... this is so or am I doing something wrong?
I have connected the fiio to the line out in the MF
Apr 15, 2017 at 2:25 PM Post #479 of 516
No...That is Right.
Bass & Treble settings only available for E17k's when the internal amp is in use...That is Headphone Out.
Apr 15, 2017 at 2:30 PM Post #480 of 516
No...That is Right.
 Thanks Ab10
