kops05
- Oct 6, 2014
the operate system is windows 8.1.Sorry but im knew in this staff. I bought the cable cause I never thought that it may not work. now im kind lost
The cable is male to male (3.5mm to 3.5mm) to use it from the phone to the Cayin and then the earphones connected directly to the Cayin. I thought with this method im getting the best of them but its like I was wrong
Thanks again for your help.Just last question before I buy it. If it was you,you would do this or you would buy a fiio x3 audio player and just connect the IEM earphones in it? Maybe the signal of the fiio x3 will sound better and the sound quality for the music would be better?
I'd go Fiio X3 into Fiio E12 into T90 and call it a day :3
u can use the Cayain c5 you already have as well.
Tbh, that would be a stupid idea.
For what exactly do you ened a Fiio E12, when you already have a X3? Thats not just a DAC; but also an Amplifier. And it has by far more than enough power, to drive a T90.
And regarding to any in-ears.. Its there also enough. The X3 has already near 0 Ohm output impedance. Any additional Amp like the E12 would be NOTHING but a pure 130 dollar decoration without any purpose. It will not sound better and the output impedance isnt lower = useless.
An additional Amplifier is worth buying if you have one or both of these issues:
- Its not loud enough / output power is too low
- Output impedance is too high, and desturbing the frequency response of Multi BA-inears.
Wow seriously...
How about "An additional Amplifier is worth buying if you..."
Want a nice analog volume control like the E12 provides.
Want to reduce the power consumption of the X3 by not having to switch it into high gain battery eater mode to drive high Z cans properly. (DT880's for example)
Want a little Bass boost at the flick of a switch, because we all know how amazing the UI is on the X3 ever since they took out the tone controls from the quick menu.
So definetily I made my choice and ordered the fiio x3. im sure the sound will be nicer and cleaner instead of playing it on my nokia lumia 1520 plus amp. im sorry but I cant afford to buy the fiio x3+fiioe12+T90 they worth 160+130+630 so means nearly one thousand dollars.my budget is 400 dollars. I spend 140 on fiio x3 and now remains me around 220 dollars to buy a good pair of headphones. Any suggestions so I don't waist my money?. I bought few years ago the pioneer hdj 2000 from ebay only to find out few weeks ago that are fake .I was undiceded between ath-m50x, AKG-K551 or Beyerdynamics DT 1350. What do you think will sound better with Fiio x3?
Don't be offended Mshenay I don't think he wanted to offend you. He just strongly believe I don't need a Fiio e12 on the Fiio x3 to work out the headphones properly. Thanks both of you for your own opinion and suggestions
Wow seriously...
So maybe just a "stupid idea" for you.
And, to be honest, These small gimicks are worth an extra 130 bucks for you? Maybe you thought about that there arent many people to throw hundreds of dollars/euro around like its nothing, when its just small gimmicks you get.
As if 130 bucks extra just for a volume knob + faster bass-boost switch doesnt sound a bit worthless / "not smart way to spend money"
If you get the E12 anyway, then you can just use your smartphone as source. Its not like the X3 sounds better than some smartphones (for example htc one m7 / m8 are on a similar level, Tested with 400 bucks in-ears.).
Since most people have their smartphone anyway, why carry 3 devices?
Except of course, you dont own a smartphone / have a 10+ year old nokia brick.
And inears aside, for what purpose exactly do you need a MOBILE music player for headphones, that are not useable for any mobile purpose because they are open cans? DT 880, T90 might sound great, but they suck for mobile usage because they leak sound. And their cable is too long.
@ kops05: well, which sound better depends on YOUR personal opinion. One might prefer the dt 1350, others the m50. They sound different, are all a good suggestion. But which YOU like most, you will have to try on your own. If you have any chance, try all / order all, and send the others back.
If you want to use them mobile (train, bus etc), they just have to be closed cans.
