dL.
- Dec 29, 2009
Hello,
For those who have a Mac and a Fiio E10, can you please help me test something?
Do you guys notice that the built-in Mac sound effects, such as emptying trash, moving files or folders from one location to another and so forth sounds really weird? It sounds as if it is skipping and not really playing the beginning or not playing till the end. Some effect sounds fine while others are not. I tried this with 2 sets of E10 and 2 different Macs with different USB ports and they all exhibit the same problem.
How to test?
Go to System Preference > Sound > Sound Effect. Simply play the default sound "Funk" or any other sound. Compare that with the internal speaker of your Mac or your other DACs and you should notice that the E10 makes the sound effect really weird.
However, everything else plays and sounds perfectly fine. I wonder why this would be the case? Is the E10 defective or is there some technical glitch or the nature of technology?
Thanks!
dL
How to test?
Thanks!
dL
