Thank you, @FiiO Willson , for the detailed and kind explanation! I, as well, believe that the cable is faulty. I have tested the 4.4mm plug with my HOOK-X stock cable and it works fine. I just wanted to post here to make people aware of this issue. I have already emailed Penon Audio. I will most probably get a replacement,
[FiiO BTR7] Portable Bluetooth Amplifier, Color IPS display,High-performance DAC ES9219C*2,THX AAA-28*2 amps,3.5+4.4mm outputs,One-click “dongle” mode
- Thread starter FiiO
I believe youI had no Problems with the 4.4mm female at my M11Plus ltd, Cayin RU6, BTR7, NX7 with 4.4mm male: Dunu, Gekerika, IMR, DD-Hifi (adaptor). So I would guess it's Pennons Adaptor.
I never expected this to happen, especially since the PAC cable is highly recommended for the Tansio Mirai Sands. I have waited for 20+ days for this cable to arrive, now I need to send it back and get a replacement.
Just ordered the Fiio BTR7 after checking a lot of reviews and articles. I guess it was the right decision and will future proof me for a few months...if not years Till the upgrade bug bites again
Claypole
I have a question about the EQ function: I understand that by turning the EQ function on, the volume is reduced in order to reduce clipping. However, it only does this intermittently.
Is there some reason why it would‘t drop the gain when activating the EQ?
In fact I also had a query on the EQ. Connected via Bluetooth with my iPhone and on Spotify. All the EQ presets work but the user presets don’t. Am I missing something ?
FiiO Willson
Sponsor: FiiO
First turn on the "Custom" switch, and then tap "Custom" to enter the settings.In fact I also had a query on the EQ. Connected via Bluetooth with my iPhone and on Spotify. All the EQ presets work but the user presets don’t. Am I missing something ?
I also have an iPhone, I have no problems with this operation, I do not know if you have tried this?(The screenshot I took is the Chinese interface, and the other interfaces are basically the same)
106miles
These are the pics of the english version from the Fiio website. The 3 user presets work on my android and they save by just entering the settings. However, if I reset one of the user presets, all 3 presets are reset. It would be nice if only the user eq that I am using resets and the other 2 stay unchanged.
EdgeDC
@FiiO when is this case likely to be available to buy?
Hi @FiiO (and @FiiO Willson) - it’s now 1 month later. Any more word on the new leather case with belt clip?Dear friend,
About 1 month later if everything goes well.
Best regards
Thank you for the explanation. Will try this and update.First turn on the "Custom" switch, and then tap "Custom" to enter the settings.
Dear friend,These are the pics of the english version from the Fiio website. The 3 user presets work on my android and they save by just entering the settings. However, if I reset one of the user presets, all 3 presets are reset. It would be nice if only the user eq that I am using resets and the other 2 stay unchanged.
The iOS version FiiO Control app in the Apple store is not compatible with the PEQ adjustment of BTR7 currently. We will fix in in next app update. You could use your Android device to set the PEQ for help.
We apologize for any inconvenience in the meantime!
Best regards
Ok noted and thanks for this update. No wonder I was unable to hear any changes in the Custom EQ. Will use the preset eqs for now.Dear friend,
Best regards
Dear friend,Hi @FiiO (and @FiiO Willson) - it’s now 1 month later. Any more word on the new leather case with belt clip?
It is now available in our Aliexpress store:
https://www.aliexpress.com/item/1005005128079584.html
Best regards
scracy
Excellent just purchased, good price too @ $21AU shippedDear friend,
Best regards
EdgeDC
Awesome, thank you - ordered!Dear friend,
Best regards
anmolkakkar
@FiiO and @FiiO Willson Any thoughts/comments on this please? It would really help. I am pretty sure this can be achieved with software as the hardware is present since you ship the device with a C-to-C cable that can be plugged to receive the audio signal from it and communicate/handshake with the connected device. So why not just output to Usb-C headphone while the BTR7 receives audio from Bluetooth.Dear @FiiO
Requesting the following enhancement if possible:
Would it possible to enable the BTR7 to route the audio through its USB-C port as well (which is currently only used for charging) when connected to our phone via any Bluetooth codec (LDAC, APTX, APTX-HD, etc.)? It would definitely help a lot to use those high fidelity USB-C type earphones that are now just lying around
Others, please feel free to add if you think it would make your lives useful. I'm definite that it will make mine.
Just like connecting a headphone to one of it's port but instead of using 3.5mm jack for output, we are using USB-C for output.
