@FiiO Hello Team, Did you manage to develop on the btr7 an PEQ like the qudelix 5k did ?
[FiiO BTR7] Portable Bluetooth Amplifier, Color IPS display,High-performance DAC ES9219C*2,THX AAA-28*2 amps,3.5+4.4mm outputs,One-click “dongle” mode
- Thread starter FiiO
jsmiller58
FiiO is working on it:@FiiO Hello Team, Did you manage to develop on the btr7 an PEQ like the qudelix 5k did ?
https://www.head-fi.org/threads/fii...7-is-officially-released.963808/post-17014359
Dear C4PPY,We where looking for if the BTR7 was Snapdragon Sound certified? And if the AptX Voice part under Aptx Adaptive was supported?
Much like what is done on the UWTS5.
Both no.
Best regards
Thank you for your answer
Let's enjoy some picture of FiiO BTR7!
Andrew_WOT
- Jan 18, 2004
Is control software available already and for which OS?
Also is there additional driver required for PC USB connection?
I have to say that I'm pretty bummed about this being based on the dated QCC5124, which only supports Bluetooth 5.0 and draws ~6ma. With LE Audio around the corner requiring Bluetooth 5.3 and LC3 support, the BTR7 is essentially obsolete already.
I had really hoped Fiio would come out with something using the QCC5171, which does BT5.3, only draws ~4ma, and supports lossless BT and LE Audio. Maybe next time.
Surf Monkey
- Nov 7, 2011
Obligatory “wait, there’s a BTR7 somewhere in these pictures? I didn’t notice.”
jsmiller58
Andrew_WOT
- Jan 18, 2004
I do not see shirt/belt clip mentioned or shown anywhere on the product page, are we going to get one as an additional accessory later, will it work with included leatherette case?
Dear Andrew_WOT,Is control software available already and for which OS?
1. Android FiiO Control 3.0 and ios FiiO Control 1.15 have added the app control for BTR7.
2. In UAC 1.0 mode, no driver is needed.
In UAC 2.0 mode, you would need to install the FiiO USB DAC driver in the Windows computer first. MAC is driverless.
Best regards
Dear Andrew_WOT,I do not see shirt/belt clip mentioned or shown anywhere on the product page, are we going to get one as an additional accessory later, will it work with included leatherette case?
We do not have the plan for the clip currently. But if the need in the market is high, we will consider about that.
Best regards
FiiO Willson
Sponsor: FiiO
Yes, It is same to BTR5Can anyone confirm that the BTR7 does multipoint like BTR5, i.e. - if connected to a Bluetooth music source and call comes in from paired pjhhone in range it will automatically switch to the call?
Related, a great feature of BTR5 is that when in use as a USB DAC to PC audio source, it also will automatically switch to a call via Bluetooth when incoming,. Same for BTR7?
ipaddy
human bean
I have to agree with Jeff.I think any consumer that doesn't do his / her own due diligence should bear some responsibility.
The phrase "slightly larger" is objectively wrong by any reasonable standard. That actual dimensions were also published does not detract from their being wrong. A consumer does not easily visualize a comparison of specifications.
If FIIO wanted to muffle the impact, a fair way of handling the issue as a response would have been to mix in the justifications (larger screen, 4.4mm) into the response sentence, and leave it at that.
Let's not be disingenuous here. Clearly, there was an intent to pretend that the dimension increase is minor.
