caustic386
- Nov 8, 2011
Very promising, our engineers are working hard to make it happen
I'm a little confused on this, so in the meantime it's a 10 band until maybe a future firmware update?
Would that also mean using the CTIA mic via BT?Sorry,
In UAC mode, it does not support computer-driven mic,
In Bluetooth mode, can only use the BTR7 mic
That doesn't look like an 84% difference. Either there's some weird optical illusion going on or I think someone's math is off lol.
I just did the math and it's a 58.4% difference. Larger a difference than it initially looks. Just by the eye test I would have said 25-30% so I can see why someone would say it's slightly larger.
I used an online difference calculator and this is what it spit out:Your math is wrong.
83.6 * 39.6 * 14.2 = 47009.952
72 * 32 * 11.2 = 25,804.8
100 * (1 - 47009.952 / 25,804.8) = 82.175%
Slight variance from previous 84% figure is because the picture shows 11.2mm for btr 5 depth, while the spec sheet lists 11.1mm.
You're calculating a measurement of the delta vs the original size instead of simply the original size vs. the new size.I used an online difference calculator and this is what it spit out:
Difference of 47009.952 and 25804.8 = |47009.952 - 25804.8|/((47009.952 + 25804.8)/2) = 21205.152/36407.376 = 0.58244109655142 = 58.244109655142%
https://www.calculator.net/percent-calculator.html?c3par1=47009.952&c3par2=25,804.8&ctype=3&x=28&y=16#pctdifference
Looking at it another way, the BTR7 is:
...than the BTR5. It's not insignificant, no. Me though? I'll reserve judgement until I see it in person, or at least pics & video alongside a BTR5. It's a matter of relative perspective and personal priorities. The way I see it, the BTR7 is both notably better featured and more powerful than the BTR5, so I don't personally begrudge the size increase that is listed. You apparently do. Fair enough.
- 16% longer
- 24% wider
- 28% thicker
In any case, it's all academic - if you don't like the size, don't buy one, right?
So what numbers would you input into the calculator? I inputted both volumes, original and new size in the calculator. If this requires a long math lesson then never mind and I'll just take your word for it.You're calculating a measurement of the delta vs the original size instead of simply the original size vs. the new size.
As much as I firmly disagree with Jeff Graw's assessment how big of a deal the size change is, I do agree with his math.
In terms of volume, the BTR7 is 84% larger than the BTR5.
The thing is, volume changes are affected by a multiplication of three dimensional changes, so it grows much faster than may seem apparent when holding the two devices. When you look at the dimensional changes individually, it's not as dramatic as 84%, but they collectively add up. From a previous comment of mine in this thread:
Switch the numbers around in the calculator. You were calculating the decrease % of a BTR5 down from a BTR7. We were talking about the increase % of the BTR7 from a BTR5. Those percentages will not be the same (yeah, math works that way, because it depends where your starting point is).So what numbers would you input into the calculator? I inputted both volumes, original and new size in the calculator. If this requires a long math lesson then never mind and I'll just take your word for it.
I wasn't calculating decrease/increase. I was calculating the difference percentage. The difference percent is the same both ways.Switch the numbers around in the calculator. You were calculating the decrease % of a BTR5 down from a BTR7. We were talking about the increased size of the BTR7 from a BTR5. Those percentages will not be the same.
If the percentage difference was the same both ways, then the calculation results would be the same regardless of which way you put them into the calculator.I wasn't calculating decrease/increase. I was calculating the difference percentage. The difference percent is the same both ways.
edit: I find this pretty interesting. So while an increase in volume of 82% may seem like a lot, it's also only a difference of 58% in volume. So i guess it's about how you perceive something. When I pick up two items, what do I immediately calculate in my mind, the difference in size or the increase in size?
Then you have to take this up with calculator.net because it's giving me the same percentage difference.If the percentage difference was the same both ways, then the calculation results would be the same regardless of which way you put them into the calculator.
Percentage increase is not the same as percentage decrease between the same two objects.
A 20 cm line is twice as long (100% longer) as a 10cm line.
A 10cm line is half as long (50% shorter) as a 20cm line.
100% and 50% are not the same percentages. It depends on which way you are calculating, and where your starting point is.
Put another way, using your numbers - the BTR7 is 82% larger than the BTR5. The BTR5 is 58% smaller than the BTR7. Both are true.
OK, let me try to put it this way.Then you have to take this up with calculator.net because it's giving me the same percentage difference.
https://www.calculator.net/percent-...3par2=25804.8&ctype=3&x=17&y=29#pctdifference
Difference of 47009.952 and 25804.8 are 58.244109655142%
Steps:
25804.8 is a 45.107793345545% decrease of 47009.952.
https://www.calculator.net/percent-...ar2=47009.952&ctype=3&x=33&y=22#pctdifference
Difference of 25804.8 and 47009.952 are 58.244109655142%
Steps:
Difference of 25804.8 and 47009.952 = |25804.8 - 47009.952|/((25804.8 + 47009.952)/2) = 21205.152/36407.376 = 0.58244109655142 = 58.244109655142%
47009.952 is a 82.175223214286% increase of 25804.8.
Steps:
Percentage of increase = |25804.8 - 47009.952|/25804.8 = 21205.152/25804.8 = 0.82175223214286 = 82.175223214286%
Now only 96 left, as I type this. Good to give people the heads up.BTW, only 97 left now, was 105 when I was ordering.
https://www.aliexpress.com/item/1005004473518477.html
yeah i know, that's what I've been trying to say.OK, let me try to put it this way.
We're not trying to calculate the "difference" here. We're trying to calculate the percentage increase in volume. That is not the same thing. Your very same calculator links also show exactly that. Right there, on both the page and your own
