@FiiO We absolutely need a belt clip! Without a belt clip, the BTR7 is useless in the streets. And the belt clip should be able to unclip very quickly in order to answer phone calls. A lanyard can be an option for those who never runs or jogs. Otherwise only a belt clip can save the day. It is desirable that it clips anywhere like to a backpack strap so it's positioned close to ones mouth in order to answer phone calls.
Another critical thing is that the case should be
black. No matter what, black is the only color that fits any clothing and style, any situation and gender. If you make a case of different color, you significantly limit the target audience.
Since the BTR7 is a very sharp brick that nearly cuts your skin in the pockets, it should be carried most of the time in a case, so the design of the case is a number one priority... This is another critical mistake made by FiiO. A portable device should never be sharp to the edges because it contacts the skin in ones pockets. Why making such a design if you absolutely have to hide it inside an ugly case?
I don't understand why FiiO's marketers and designers didn't grasp these simple but very important ideas from the get-go? Just add a 4.4mm pentaconn to a BTR5 and we are happy! The BTR5 was almost ideal in terms of design and usability. Why ruining it?
For now I'll stick with the BTR5 regardless of the technical improvements of the new device. The usability in the streets is much more important for this class of portable devices.
