@FiiO after the update I am getting only two option in the filter menu on the BTR7 - Fast and HybridF.The new firmware V1.71 for FiiO BTR7 is now available!
The following changes and improvements have been made to the FW1.71:
1. Added PEQ function (go to the EQ menu on the latest FiiO Control app for settings);
2. Changed the setting of aptX Adaptive to off by default (can be enabled on the FiiO Control app);
3. Improved the logic of UI display;
4. Improved the abnormal issue of answering phone calls through the 4.4mm headphone output;
5. Miscellaneous performance improvements and bug fixes.
Note: Please update the FiiO Control to latest version first.
BTR7 firmware download: Click here
How to upgrade the BTR7: Click here
[FiiO BTR7] Portable Bluetooth Amplifier, Color IPS display,High-performance DAC ES9219C*2,THX AAA-28*2 amps,3.5+4.4mm outputs,One-click “dongle” mode
- Thread starter FiiO
Can anyone compare the sound quality of BTR7 and BTR5 by BT (LDAC)?
scracy
Using LDAC on both the BTR7 has a more holographic, dynamic and transparent presentation than the original BTR5 not to mention considerably more power. A worthwhile upgrade in every way in my opinionCan anyone compare the sound quality of BTR7 and BTR5 by BT (LDAC)?
The DAC chip inside BTR7 only supports those two selectable filters in PCM mode. There are two unselectable / automatical filters: one for MQA and one for DSD.@FiiO after the update I am getting only two option in the filter menu on the BTR7 - Fast and HybridF.
@FiiO If the BTR7 is connected in USB DAC (dongle) mode to a phone, can it simultaneously transmit HI RES music over Bluetooth?
Andrew_WOT
- Jan 18, 2004
There is input priority setting in the Menu, you can stream over USB or BT, not both at the same time, that doesn't make much sense.
What's the final result supposed to look like?
scracy
BTR7 is a Bluetooth receiver not a transmitter, not sure what you are asking?@FiiO If the BTR7 is connected in USB DAC (dongle) mode to a phone, can it simultaneously transmit HI RES music over Bluetooth?
Dear friend,@FiiO after the update I am getting only two option in the filter menu on the BTR7 - Fast and HybridF.
The BTR7 supports two filter only. But the engineer has changed the translation in this new firmware update.
Best regards
Dear friend,@FiiO If the BTR7 is connected in USB DAC (dongle) mode to a phone, can it simultaneously transmit HI RES music over Bluetooth?
If you would like to connect two device at the same time: one via Bluetooth, one via USB, it is supported.
But the BTR7 is only a Bluetooth amp, so it could not transmit Bluetooth signal and connect to Bluetooth headphone.
Best regards
FiiO BTR7 is on the way to our worldwide sales agents!
Dear respected customers,
Thank you for your kind patience and constant attention for our BTR7. Delivery of the BTR7 has started from 3rd, August. Please kindly check this post for a daily updated list of countries / regions and agents we have sent goods to.
Japan: Emilai
USA: Office direct
US Distributor: TekFx Inc.
Canada: Canadian distributor
Russia:Blade
HongKong: Carve Link Company
Taiwan: Walkbox
Netherlands: Network Media Systems
Singapore: Eng Siang International Pte Ltd
Czekh : GOTHIC
Mexico: Audiofilia
Indonesia : PT lntium lndo Prima
Australia: Addicted To Audio
Malaysia: RedApe
India: Headphone Zone
UAE: Smart Audio Electronics Trading L.L.C
Romania: Avstore
(*The shipping to other regions will also follow soon, and we will keep updating this post)
In order to get prompt pre-sales and after-sales service, we strongly suggest you to buy FiiO products from our authorized sales agents (Where to buy).
By our estimate, it would take 5 to 7 working days for the parcels to reach our agents abroad, which means all of you can try contacting the local sales agents on about 10th August.
If you have any comments or questions, please feel free to contact us or directly contact our local agents.
Happy listening!
Best regards,
Guangzhou FiiO Electronics Technology Co., Ltd.
- May 3, 2009
Do we have a shipping date for the UK pre-order?
Edit: ignore me, didn't read the thread this morning!
@FiiO Dear friend, long time Fiio fan here (since the E3 amp at around 2009 - who remembers that!).FiiO BTR7 is on the way to our worldwide sales agents!
Japan: Emilai
USA: Office direct
Russia:Blade
Taiwan: Walkbox
Czekh : GOTHIC
Mexico: Audiofilia
Malaysia: RedApe
Romania: Avstore
Happy listening!
Best regards,
Just want to ask if you no longer have a distributor in Mauritius (an island in the Indian Ocean)? There is a store named One.O.One Multimedia which was your official stockist since 2017. Unfortunately they don't have any new Fiio gear on sale. I had to import the BTR7 and its was quite a hassle and costly for the shipping. Fortunately my unit did arrive safely and i'm really enjoying it (i do have a soft spot for the BTR5 over the BTR7 though but thats another story). Would be really sad if we could no longer procure Fiio gear locally.
I started with E1@FiiO Dear friend, long time Fiio fan here (since the E3 amp at around 2009 - who remembers that!).
IcyFlow
- Apr 24, 2014
@FiiO on firmware v1.71 the battery meter will go missing after the device is on for a while.
only way to resolve this is to restart the device
LouisLoh
- Feb 14, 2011
I just tried this at a local store. Connected to my WM1AM2 over bluetooth and all that I could hear from the 4.4 balanced output was static noises. Store owner didn't have any issues with his Galaxy Fold > BTR7 > 3.5mm. I could hear absolutely fine from my WM1AM2 > iFi Go Blu > 4.4mm.
I realised there are a few other permutations I could have tried to pin point the problem in the chain, but I ran out of time. Just wanted to put this out there, to see if any one else had this issue?
Total: 6 (members: 0, guests: 6)
