psikey
- Jul 15, 2008
Again, you not even reading my answer. It has nothing to do with balanced or not. SE846 doesn't need more voltage. It needs current. And a lot of it. Even ES100 is below specs. BTR3 is twice lower maximum current ability. Because it has only ONE amp.
P.S. Just if you don't know - ES100 works in dual mono and in tandem mode. So balanced or unbalanced - it can use both amps at the same time.
I'm no expert on this stuff, so are you saying the BTR3 won't drive the SE846's to loud volume or that the audio quality will be poor with artefacts/noise etc ?
