FiiO BTR3-The World' First Bluetooth Headphone Amplifier, SBC/AAC/aptX/aptX LL/aptX HD/LDAC/HWA (LHDC)
Aug 9, 2018 at 5:34 AM Post #16 of 1,870
Is it going to be sold on Amazon (or just the FiiO Aliexpress store)?
Is playback available while charging?
Thanks
Yes, you could use the BTR3 while charging still. But it is recommended to use it after charging fully.
Best regards
Aug 9, 2018 at 6:40 AM Post #20 of 1,870
@FiiO :
I see the BTR3 supports LDAC but I haven't read which of the 3 LDAC versions.
Does it support :
  1. LDAC (Connection) = 330kbps (so aptX is better @352kbps)
  2. LDAC (Normal) = 660kbps
  3. LDAC (Quality) = 990kbps
And does the Fiio M7 support these 3 too? (Answered myself : Yes it does)
Thanks in advance for your answer.
Aug 9, 2018 at 7:10 AM Post #21 of 1,870
I didn't see this info in any of the promo info that was released. Which version of Bluetooth is it; 4.1, 4.2, or 5.0?
Aug 9, 2018 at 8:07 AM Post #23 of 1,870
Thanks for your kind attention! The worldwide delivery probably start tomorrow, so you may check with local sales agent around Aug. 20th: https://www.fiio.com/newsinfo/46664.html
Been waiting for this one ever since I heard about it from CanJam London, hopefully Amazon will have it when it first comes out. I'm definitely getting one, currently using the BTR1 and loving it.
Aug 10, 2018 at 2:34 AM Post #28 of 1,870
I first need to know which of the 3 LDAC versions it supports.
I already have the uBTR and it's only for the LDAC support that I could be tempted to buy another.
But if it, for example, only supports LDAC Connection it would be useless to me.
You won't be able to distinguish which of the 3 versions of LDAC is used since they all have the same LED color (if all 3 LDAC variants are supported that is).
Aug 10, 2018 at 5:35 AM Post #30 of 1,870
ordered one on tmall.
Regarding ldac,- is it not source dependent if it uses 330, 660 or 990?
That too, ofcourse.
But, like many devices support aptX but not aptX HD, it's, afaik, very well possible that a device only supports LDAC Connection.
And if that's the case you are better off with aptX.
And, because the light on the BTX3 just shows that you have a LDAC connection, you never know if you have a 330, 660 or 990kbps connection.
