FiiO BTR3-The World' First Bluetooth Headphone Amplifier, SBC/AAC/aptX/aptX LL/aptX HD/LDAC/HWA (LHDC)
speedingcheetah
The BTR3 is a bit of a bugger with my 2019 Nvidia Shield Pro.
Doesn't seem to like it.
It pairs fine, uses LDAC.
But it cuts out for second, ever couple minutes, as if there is interference.
Range is also very poor, cuts out entirely if i leave the room.
I have 2 different sets of Sony BT in ear headphones, that work with no issues with the Shield.
Very rarely do they have any drops or glitches.
They also stay connected around my entire apartment unit.
I have tried to force the used of AptX or AAC etc, via the Android Dev settings, however, that does not seem do anything, even after re-connect, the system will always default to LDAC.
The BTR3 has no such cut out or range issues when it is paired to my Win 10 Laptop(AptX) or my Pixel 3 (LDAC).
use the fiio player app, connect the btr3 and choose the bt codec to be turned off, in your case the ldac and maybe hwaThe BTR3 is a bit of a bugger with my 2019 Nvidia Shield Pro.
speedingcheetah
No. because I want LDAC,,, that is the bloody point of this DAC is that is does LDAC for the better quality.use the fiio player app, connect the btr3 and choose the bt codec to be turned off, in your case the ldac and maybe hwa
Also, it has already been told here that HWA is a codec for only Huawei brand devices and is never in use anywhere else.
Second, the Fioo app stopped seeing the BTR3 last time i tired to adjust the EQ.
if your shield cant do with the dropouts, compromise, give and take, try not to be overly obsessed with LDAC, they are good but not THAT goodNo. because I want LDAC,,, that is the bloody point of this DAC is that is does LDAC for the better quality.
speedingcheetah
Fioo app doe snot show up in the app store on the Shield.
It works fine with all other BT devices, the SONY audio products that do use LDAC as well, so it is clearly not a Shield or environmental issue.
It is not a big deal as i just use use the sony headphone when I need to use headphones late at night.
I was just posting here my experience with the BTR3 and the Shield.
There is nothing that can be done further.
Some BT chips just don't get along with others.
And the BTR3 works fine on the phones i have tried.
android variety is indeed a pain to uniformity
speedingcheetah
Uniformity as whole, is inherently insecure. U hack one, u hack them all....looking at u Apple.android variety is indeed a pain to uniformity
I would be using a pure linux device or Win phone...no none used win phone, no malware, viruses, no one cared about the platform...so no one wasted their time to attack the few users there were....
LOLZ
tyota
Love my BTR3, but with the new BTR5, what to do?
tmb821
Does the eq only work through the fiio app? I stream amazon music from my iPhone XR. Will the btr3 apply the eq settings to that, or only what’s streamed through the fiio app.
Dear friend,Does the eq only work through the fiio app? I stream amazon music from my iPhone XR. Will the btr3 apply the eq settings to that, or only what’s streamed through the fiio app.
Did you set the EQ for BTR3 from FiiO Music app-Bluetooth device control -BTR3-EQ instead of the EQ option in FiiO Music app?
Best regards
tmb821
Dear friend,
Best regards
I don’t have one of these yet. I’m trying to decide if it will help with my issue. I have a hearing impairment, about 35% overall, with most of it falling in the midrange and vocal frequencies. I’m hoping with a eq I will be able to boost the midrange so I don’t have to use such a high volume level. As of now I have to use a volume level that causes distortion in the bass and sibilance in the highs, or I can’t clearly hear the vocals and midrange. I just want to have a fuller experience. I guess I’m asking if the device will apply the eq settings to any music played through it, or only music played through the fiio music player. iOS will only apply its eq to iTunes music. thanks.
Crixus00
- Nov 15, 2011
I have recently upgraded my mobile phone from Samsung S8 to the Samsung Note 10+. With Samsung S8 I found the max volume to be barely just enough. For whatever reason my new Note 10 appears to have about 30% more volume on tap. Sound wise, with the AKG N5005, both phones pair really well with the BTR3.
That said, I will be upgrading to the BTR5 when it becomes more widely available
S8 that generation i think is only up to AAC or maybe APTX? Note 10+ has every BT codec except APTX HD, that could be why maybe? android generation differenceI have recently upgraded my mobile phone from Samsung S8 to the Samsung Note 10+. With Samsung S8 I found the max volume to be barely just enough. For whatever reason my new Note 10 appears to have about 30% more volume on tap. Sound wise, with the AKG N5005, both phones pair really well with the BTR3.
Kundi
I tried to search this forum so apologies if this has been answered. The output for the BTR3 is so low that I have to turn it up all the way to hear anything. I don’t have this issue with the ES100. Is this an issue? Can it be fixed?
