Surf Monkey
- Nov 7, 2011
No one's come out with a clip case yet for this?
Not that I’ve seen. The plastic one for the 5 was perfectly functional. Why not just make one like that for the 7?
Nice, you can share your thoughts about it when you have it. I'm still considering itInteresting. I hadn’t upgraded the firmware so I didn’t experience that bug.
I agree that the BTR5 is a great device. It’s been a real work horse for me. It handles everything I throw at it and has enough power for most of my sets. I like the slim and small form factor too.
The BTR7 does look like a nice upgrade and that’s why I ordered one right away. I’d been thinking about the upgrade anyway so the accident with the 5 simply forced my hand.
I’m still surprised I managed to shatter the screen. It’s so light weight that it doesn’t have a lot of momentum. But it only takes one sharp edge to hit it just right…
BRT7 here I come!
Of course I'm sure, i own it. The EQ is available in both USB wired and Bluetooth LDAC modes
That's how I mostly use my BTR5, I don't think it will be any different on BTR 7Can the btr7 be used as a wired dac/AMP if it's out if battery? USB powered?
Thanks for your impressions. I might soon go for the same train tooBTR7 in hand. It’s a solid unit. It feels much the same as the BTR5 only with corners.
I can see why there was some momentary controversy about the size. It isn’t “a little bigger” than the BTR5. It’s almost twice as big. I think someone calculated that it’s about 85% bigger than the 5? That seems right to me. It’s longer, thicker and wider than the BTR5.
That said, the size isn’t an issue for me. It’s very lightweight and totally pocketable. A clip would be nice, but I didn’t use the clip on the 5, so I don’t miss it. I like the feel of it in hand and the OLED screen is very nice. I like the little faux leather case it comes with too.
As to the sound, so far so good. It’s significantly more powerful than the BTR5, and I’m really noticing that with the OH10 Obsidian, which is giving me a richer and more detailed sound than with the 5. The profile seems about the same, maybe just a touch warmer.
Finally, I haven’t tried it in Bluetooth mode yet but I’ll get to that soon. Overall I’m really pleased with it out of the box.
14. If the BTR7 is used as a dongle DAC with the charging switch off, how long is its battery life?
It has about 4.5 hours for the 3.5mm output, and about 4 hours for the 4.4mm balanced output.
15. Can the BTR7 be used as a dongle DAC when it is out of power?
No. It needs to be charged.
If the charging switch is turned off, the BTR7 will not be charged even when connecting to a USB cable. At this time, it will consume the power of the built-in battery.
Bottom line yes you will hear a significant improvement in overall sound quality even with 320kbps MP3 with the BTR7 vs BTR3KHi,
I currently have a BTR3K, is the sound from the BTR7 over bluetooth much better? If so, will I recognize it even if I only listen to MP3 320kbps? Please note that I really only listen via BT. My headphones are Custom Art FIBAE 7. Thanks![]()
I have owned BTR3K and BTR5 (pre 2021) and there is a significant difference in sound quality between BTR3K and BTR5. However the BTR7 is superior to both largely due to the THX AAA-28 amps. As far as using MP3 320kbps goes really there is not a huge difference between that and a FLAC file in terms of sound quality at least not to my ears.Thanks, and between BTR5 and BTR7?![]()
The charging switch needs to be set to ON for the battery to charge from the USB port. I just tried this with my BTR7, and got it to go from 80% to 100% charge while playing an MQA-encoded album as a USB DAC from my Android phone.That doesn't seem to be the case? so does this mean it can't be used as a Desktop DAC/AMP / USB Powered? anyone with a BTR7 can confirm? @FiiO
