[FiiO BTR17/BTR7] True Lossless Bluetooth, Portable Bluetooth DAC and Headphone Amplifier BTR17 Is Officially Released!
Aug 5, 2023 at 1:33 PM Post #1,861 of 3,460
Got one of these available at a steep discount, check the signature :)
Aug 5, 2023 at 1:54 PM Post #1,862 of 3,460
why is the es9219c insisted on such models? is it about power consumption? i don't remember a device that i was happy with, es9219c, including btr5k 2021. i know the chip doesn't matter much but when i see 9219 i stop ordering that thing
Aug 11, 2023 at 4:33 AM Post #1,864 of 3,460
Any comparison between the btr7 and btr5?
Dear friend,
You may check some reviews for help.
For example: https://www.head-fi.org/showcase/fiio-btr7.25949/reviews#review-29532
Compared to the BTR5 (original version)
The BTR7 is finer sounding, it has better clarity, greater definition, it is more resolving and extended to both ends of the spectrum, it has higher quality texture, more natural timbre and greater dynamics.
It can drive demanding earphones and if you don't mind the extra bulk then sound-wise it is a definite upgrade.
I don't have the BTR5 2021 version which uses the same DAC chip as the BTR7 but I doubt if it can compete with it in raw power, shear dynamics and overall realism.
Best regards
Aug 14, 2023 at 3:57 PM Post #1,865 of 3,460
Just going to leave this here:
Aug 17, 2023 at 3:16 PM Post #1,869 of 3,460
Since a few days I have the following issue, when using the BTR7 via the included lightning cable and my iphone 13. Apple Music stops every time when I want to change music or check email and so on. When I restart Apple Music, the music comes for a second from the loudspeaker of the iphone Before it comes from the headphone. When I use another (longer) OTG lightning cable this does not happen, everything is fine. Alos everything is fine when I use the included usb-c cable with an OTG adapter.
Aug 17, 2023 at 4:59 PM Post #1,870 of 3,460
I can’t say I’ve run into that exact weirdness with mine, but I’ve seen similar behaviour when using short cables with other equipment.
…could be a break in one of the cores of the original cable maybe?
Aug 18, 2023 at 3:17 AM Post #1,871 of 3,460
Dear friend,
It seems to be the hardware issue with the included lightning cable. You may try to reset the BTR7 and turn off the charge switch again for check first?
Best regards
Aug 18, 2023 at 9:20 AM Post #1,872 of 3,460
I will do this And report.
Edit: I have done so, but the issue remains. When listening to music and clicking on the airplay section, the connection to the Fiio BTR7 will be interrupted and it takes a few seconds til it is connected again. When chosing the next song. The music stops, after pressing play it takes a few seconds til the music play again. No issues when using another otg cable or an otg adapter with the included usb c cable. So I think the cable has a damage. How can I get a substitute?
Aug 29, 2023 at 3:29 AM Post #1,874 of 3,460
@FiiO Dear Fiio, can you make the custom EQ / PEQ can be saved as custom name (example our personal IEM name like "Mest" or "FH9" )instead of user1, user2 etc?
That will be very helpful
And if possible, put more slots for custom EQ / PEQ and custom name also.
Like 10 user preset with custom name? Or at least 5 or 7 for user with many IEMs.
Thanks in advance
Aug 30, 2023 at 3:18 AM Post #1,875 of 3,460
Thanks in advance
Dear friend,
We have reported this feedback to the engineer and they are still assessing. We will try to report again.
Best regards
