I have owned the BTR5 2021 for almost a year. Thanks for the last update of the firmware so that it can be recognized by Tidal app in android device. Recently, I have change my android phone to Samsung S22 Ultra and tried to connect the BTR5 2021 through the USB-C cable. The Tidal app cannot recognize the BTR5 2021 and cannot do the MQA decode. However, if I using the USB Audio Player Pro app in the phone, it can successfully connect with the BTR and do the MQA decode.
The Tidal app version using: 2.72.0
Android version: Android 12
Grateful if you could have advice on my case.
Thank you.
@FiiO Support
Upgrade to 2.73 version, Tidal 2.72 can’t detect any external DAC - Tested with BTR7 as well iFi Go Bar in several Android Device. Last version that support problem free external USB DAC was 2.71.1.
https://www.apkmirror.com/apk/tidal/
