[FiiO BTR15/BTR5 2021/BTR5]Bluetooth DAC and Headphone Amplifier Discussion & Impressions Thread
May 4, 2022 at 9:14 PM Post #2,986 of 3,639
Many thanks.
I do not know if this applies for both models.
What driver do you use in Windows, Microsoft or Fiio?
Does it prompt you to be in charge mode or not, and if so what do you select there?
@Can someone else confirm if this somehow also should work for FiiO BTR5 2021?
Dear friend,
Yes, the BTR5 2021 can connect to two devices(one via Bluetooth and the other via USB) at the same time. And you could switch the input priority via the FiiO Control app: https://forum.fiio.com/note/showNoteContent.do?id=202109101657246451149
Best regards
May 5, 2022 at 3:31 AM Post #2,987 of 3,639
Dear friend,
Best regards
It is working :)
I have one question, I have Office 365 on both computer and phone, and if I am in a MS Teams call on computer, and receive for example an e-mail this gives an notification on my phone, and due to the phone being Bluetooth connected to the Fiio, the sound in the MS Teams call is muted for several seconds, is there any way to shorten the mute period?
May 5, 2022 at 6:45 PM Post #2,988 of 3,639
I just got one of these. The iFi Go Blu was also on my potentials list but at nearly twice the price and no specific feature upgrade the BTR5 2021 won out over it. iOS app support was also a factor in Fiio’s favor.
This is a great little box. So far I’m running it single ended into a set of Hifiman Deva Pros and it’s working perfectly. Setup on the device was very simple and the fine tuning in the app is a nice addition. I like being able to customize resistance and sensitivity for specific phones. It sounds very good so far too. I don’t hear any hiss and it’s signature must be very flat because the tonality of the Deva Pro is the same wired as it is over the BTR5 2021.
May 6, 2022 at 11:55 AM Post #2,989 of 3,639
Dear friend,
Best regards
Hello,
I was interested in knowing when the new version of this bluetooth dac/amp will come out, maybe btr6 or btr5k (I don't know), with a better microphone maybe and with more power and battery, do you already have it in the plans?, thanks.
If you guys don't even plan on it... I guess I'd rush to buy this 2021 version.
May 6, 2022 at 12:52 PM Post #2,990 of 3,639
May 6, 2022 at 1:02 PM Post #2,992 of 3,639
Hello,
BTR6 is impossible, FiiO never uses even numbers for its models :stuck_out_tongue_winking_eye:
May 7, 2022 at 10:16 AM Post #2,994 of 3,639
May 7, 2022 at 10:20 AM Post #2,995 of 3,639
To be honest i don't like this design very much, it takes the form of the M17, suitable for an object of that size but not for such a small one. I think the design of the BTR5 is far more beautiful
May 8, 2022 at 1:11 AM Post #2,997 of 3,639
Resistance and sensitivity are there for you to fill and get an idea for the power output, it's not for customizing the sound of the phones... Have fun.
May 8, 2022 at 3:54 AM Post #2,999 of 3,639
Seems to be legit. Items shown in Spring Headphones Festival 2022 mini
https://av.watch.impress.co.jp/docs/news/1406705.html
Fiio BTR7 (approx, 30.000 yen/$230)
- 3.5mm + 4.4mm
- Dual DAC ES9219
- bluetooth QCC5124 (Fiio Q5s + Qudelix Bluetooth chip,)
- unspecified XMOS USB
- THX AAA amplifier circuit
- 1.3-inch, 240 x 240 dot IPS
Hopefully have bigger/longer battery and much better bluetooth antenna
Fiio KA1 (approx 8000 yen/ $60)
- 3.5mm
- DAC ES9281AC PRO
- USB-C/Lighting connector
Tempotec/Sonata contender?
May 8, 2022 at 10:02 AM Post #3,000 of 3,639
To be clear, do those settings affect how the BTR5 interacts electronically with headphones in any way, or do they affect the power delivery at all? If not I don't see their purpose.
