It would randomly brick itself if you use the EQ function and the audio cuts off sometimesI would like to buy a BTR5 2021, but which other problems does it has?
[FiiO BTR15/BTR5 2021/BTR5]Bluetooth DAC and Headphone Amplifier Discussion & Impressions Thread
- Thread starter FiiO
Hello I have a question whether fiio btr5 2021 mqa will spread wings in developing mqa above 96 khz This is the maximum development I can see In the advertising brochure, expansion x16Dear friend,
Thanks for your interest in our product. You could try it in the local store first:https://www.fiio.com/wheretobuy
Or read some reviews by other users.
Best regards
Regards
Dear friend,Hello I have a question whether fiio btr5 2021 mqa will spread wings in developing mqa above 96 khz This is the maximum development I can see In the advertising brochure, expansion x16
Regards
BTR5 2021 supports up to MQA 16x decoding with applicable music apps. Do you mean playing MQA file in 96kHz?
You could also read the MQA website for more information: https://www.mqa.co.uk/how-it-works
Best regards
Distinguished FiiO users,
In order to better know the usage scenarios and further improve our products, we are making a questionnaire about Portable DAC/Amps and would like to invite you to participate in it. Thank you so much for your time and support.
Link: https://forms.gle/MszZKV8fKDLdeQ2C9
Any new BTR with 4.4mm anytime soon / far ?
https://hxosplus.gr/gadgetech/fiio-btr7-bluetooth/Any new BTR with 4.4mm anytime soon / far ?
Nas Volokin
Well that looks interesting Is it confirmed?
Not officially but where is smoke there is fireWell that looks interesting Is it confirmed?
Filled out.Distinguished FiiO users,
If I where to suggest an improvement for BTR5 2021 then it would be the possibility to connect to computer through USB, while at the same time have being connected through Bluetooth to phone.
This would make it possible to hear music from computer, while being able to receive phone calls at the same time.
I have the OG BTR5 and it does function exactly as you describe.Filled out.
So you can listen to music using USB from computer, and then receive a phone call on the mobile through bluetooth on the headphones connected to the BTR5?I have the OG BTR5 and it does function exactly as you describe.
Yes, exactly correct. The call interrupts the music playback when I answer by pressing the middle BTR5 button.
Many thanks.Yes, exactly correct. The call interrupts the music playback when I answer by pressing the middle BTR5 button.
I do not know if this applies for both models.
What driver do you use in Windows, Microsoft or Fiio?
Does it prompt you to be in charge mode or not, and if so what do you select there?
@Can someone else confirm if this somehow also should work for FiiO BTR5 2021?
I use USB Audio driver from FiiO, I believe charging is on, bluetooth of course on as well.
Super, thanks I will give it another tryI use USB Audio driver from FiiO, I believe charging is on, bluetooth of course on as well.
Total: 23 (members: 0, guests: 23)
