Hello, can you suggest me some cables from amazon to connect the btr5 to my xiaomi redmi note 8 in usb dac mode?
[FiiO BTR15/BTR5 2021/BTR5]Bluetooth DAC and Headphone Amplifier Discussion & Impressions Thread
- Thread starter FiiO
Can you link the exact cable please? I've never used them. Thank youI use ugreen from AE. Works well, good quality.
Devodonaldson
Definitely. I have several android phones, and have used an iPhone 7 as digital transport for the last year and a half due to the beautiful bit-perfect transport to all apps for audio. But when it comes to Bluetooth listening, LDAC beats it hands down. It has to do with the amount of information and basically the cutoff freq of the different codes. AAC rolls off a little earlier than APTX definitely earlier than APTX HD, and you hear even more of the top end with LDAC. it's the upper frequencies where the lower codecs begin to fail and that plays a part in staging feel, transparency, and detail.Has anyone ever compared the sound quality differences between LDAC and ACC.
I have iPhone can only use ACC and always wonder how much I’m missing out
Green Golden Retriver
I never have android phone ><Definitely. I have several android phones, and have used an iPhone 7 as digital transport for the last year and a half due to the beautiful bit-perfect transport to all apps for audio. But when it comes to Bluetooth listening, LDAC beats it hands down. It has to do with the amount of information and basically the cutoff freq of the different codes. AAC rolls off a little earlier than APTX definitely earlier than APTX HD, and you hear even more of the top end with LDAC. it's the upper frequencies where the lower codecs begin to fail and that plays a part in staging feel, transparency, and detail.
iphone 4 then 6 plus then X.
when will iphone ever support Ldac ><
Anyway thanks for your detailed explanation
Devodonaldson
Iphone will NEVER support LDAC. It's built its system on AAC. Honestly not focused on audio quality, rather overall user experience, etc. IOS audio is coded in AAC, so no additional. No conversion necessary.I never have android phone ><
Ahhhh that sucks.Iphone will NEVER support LDAC. It's built its system on AAC. Honestly not focused on audio quality, rather overall user experience, etc. IOS audio is coded in AAC, so no additional. No conversion necessary.
maybe someday I will switch to Android. lol
To use my current iems (KZ ZS10 Pro and Blon BL 03) with the BTR5 balanced output just take a simple 2.5mm NICEHCK 8 Core copper cable?
No problem? Need anything else? thanks a lot
SenorChang8
That’s it, I assume you’ll be using an audio source via Bluetooth and/or USB?
[QUOTE = "SenorChang8, post: 15902236, membro: 533341"]
È così, presumo che utilizzerai una sorgente audio tramite Bluetooth e / o USB?
[/CITAZIONE]
Sì, smartphone and laptop
[/CITAZIONE]
Actually whether it is iOS or Android, or whether the music is AAC or not doesn't matter much to the Bluetooth chip. When sound is sent over BT, it will always get decoded back to PCM first, then re-encoded using the BT codec (AAC or LDAC, or any codec both transmitter and receiver agreed to use). So even for iOS devices, AAC encoded music will get decoded back to PCM first, then recoded back to AAC for BT transmission. Hence the process is always lossy and you will take a hit on SQ technically.
lucasd
- Feb 1, 2005
You cannot compare AAC on android vs iphone. AAC on iphone is much better optimized and is visible in tests.Iphone will NEVER support LDAC. It's built its system on AAC. Honestly not focused on audio quality, rather overall user experience, etc. IOS audio is coded in AAC, so no additional. No conversion necessary.
However LDAC would have advantage but it is not going to happen.
To easy see possible difference compare BT vs on cable (LDAC will be worse than this, but closer than AAC).
Devodonaldson
Or, just get a good used android phone with micro SD and use as a portable media player.Ahhhh that sucks.
big45-70
- Nov 3, 2013
I just think of Bluetooth for convince and wired for quality. Just like anything else... wifi vs wired internet etc
Total: 13 (members: 0, guests: 13)
