helmutcheese
This late in the day why did you not update it to BT 5.2 and add aptX Adaptive?
You would need to install the DAC driver first for higher sampling rate supporting.Do you need to install windows drivers or will windows 10 automatically detect it with the highjer bitrates?
The developing time and hardware limitation not allow us to update this for the BTA30Pro. You could wait for our newer product instead.This late in the day why did you not update it to BT 5.2 and add aptX Adaptive?
Dear friend,I've just recieved my fiio bta30pro and it wont connect to my fiio m11pro DAP via bluetooth, any suggestions?
I am trying to use the BTA30 Pro as the transmitter and the M11 Pro as the receiver, and won't show up in my list of Bluetooth devices available. I was hoping to use this with my PS4/TV since the PS4 doesn't seem to connect to any Bluetooth device I have, which is why I went with the BTA30 Pro. I will also be using it to transmit audio from my laptop occasionally.Dear friend,
You are using the BTA30Pro as Bluetooth receiver or transmitter? It is not compatible with the M11Pro when working as transmitter.
Best regards
Dear friend,I am trying to use the BTA30 Pro as the transmitter and the M11 Pro as the receiver, and won't show up in my list of Bluetooth devices available. I was hoping to use this with my PS4/TV since the PS4 doesn't seem to connect to any Bluetooth device I have, which is why I went with the BTA30 Pro. I will also be using it to transmit audio from my laptop occasionally.
Update
I tried installing the Windows codec and still no luck. I then moved to the ps4/tv and no luck connecting my M11Pro as a reciever. If i turn off the bluetooth dac/amp mode on the m11pro, the bta30 pro shows up in bluetooth devices but won't actually pair.
I tried connecting with my note10+ to no avail. I will try connecting my LC-BT2(not ideal) and i also have a vmoda bt adapter for my m100 but it only has aptX. Bummer i either misunderstood what the BTA30Pro does or I'm doing something wrong. I have no issues with connecting my phone/m11pro in either tx/rx mode over bluetooth with no issues, even with LDAC using the fiio music app, so it's frustrating that this won't connect as easily.
Dear friend,Just got the bta30 pro past 2 days. Some of my experiences:
1) Wish it had a separate power switch - instead of 3-secs pair mode then 5-secs to switch off on the same switch. Can later firmware include double or triple-click power-off or something similar?
2) Connecting to previously paired receivers (Q5K, Go Blu, WH2) is not consistent. Occasionally it works. Mostly, had to power reset or re-pair again.
3) Sounds fuller/richer connecting via LDAC playing tidal on Win10 than with Pixel3 or Sony ZX1 phones via LDAC hosting UAPP-tidal. It's quite noticeable. Maybe it's the better DAC or connecting at 990kbps consistently; it sounds good.
4) FiiO Control app doesn't see the BTA30 pro. Win10 drivers is installed.
5) Couldn't fully pair with FiiO FW1. Can only get it working with one earpiece but not both.
