Can I ask, in DAC mode, does the BTA30 Pro accept Bitstream DTS. I tried connecting via USB to Coaxial port but it didn't work.
[FiiO BTA30Pro] Create a Comprehensive Home Bluetooth System, FiiO's High Fidelity Bluetooth Transceiver BTA30 Pro!
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
- Thread starter FiiO
- Tags
- fiio fiio bta30 pro
Dear friend,Can I ask, in DAC mode, does the BTA30 Pro accept Bitstream DTS. I tried connecting via USB to Coaxial port but it didn't work.
The BTA30 Pro support stereo but not multichannel DTS.
Best regards
Thanks a lot, I ran the DPInstall.bat again and restarted. I think mainly restarting did the trick and the firmware update succeeded this time.Dear friend,
1. Please check whether the update package have been unzipped completely?
2. Enter lib folder, then run the DPInstall.bat and vcredist_x86.exe manually. And restart your computer.
Best regards
Sorry, for the confusion - I usually do not restart for several weeks/months.
Just ordered mine, I will have it tomorrow
Glad to hear about that!Thanks a lot, I ran the DPInstall.bat again and restarted. I think mainly restarting did the trick and the firmware update succeeded this time.
Sorry, for the confusion - I usually do not restart for several weeks/months.![]()
Thanks for the kind feedback!
Best regards
Can the BTA30 Pro connect to an XBOX Series S?
It seems the Xbox Series S has USB output port, you could try whether the USB connection works if you don't mind.Can the BTA30 Pro connect to an XBOX Series S?
Best regards
I've received my BTA30 Pro and updated to the latest stable firmware and Bluetooth. I've paired it with my Qudelix-5K using LDAC. Is it not possible to skip to next/previous track from the Qudelix? Only Play/Pause and Volume up/down works from the Qudelix, itself. Also, in the Qudelix, the Source, so the BTA30 Pro, appears as an alphanumeric, or something. Something like 40:ed:98:1b.... Is it possible to rename that to BTA30 Pro?
Yes, the next/previous from Bluetooth receiver would not work when connecting to BTA30Pro.I've received my BTA30 Pro and updated to the latest stable firmware and Bluetooth. I've paired it with my Qudelix-5K using LDAC. Is it not possible to skip to next/previous track from the Qudelix? Only Play/Pause and Volume up/down works from the Qudelix, itself. Also, in the Qudelix, the Source, so the BTA30 Pro, appears as an alphanumeric, or something. Something like 40:ed:98:1b.... Is it possible to rename that to BTA30 Pro?
For the second problem, you may try to clear the pairing and reconnect to see whether it helps?
Best regards
@FiiO , @FiiO Willson , can the BTA30 Pro support LHDC? If not, is it possible to add support for this in a future firmware update?
Thanks for the interest. We do not have the plan for adding LHDC support in BTA30Pro currently.@FiiO , @FiiO Willson , can the BTA30 Pro support LHDC? If not, is it possible to add support for this in a future firmware update?
Best regards
Why not? Is this a hardware limitation or something else? Now that your UTWS5 will start supporting LHDC, wouldn't it be great if the BTA30 Pro would support this codec, as well?Thanks for the interest. We do not have the plan for adding LHDC support in BTA30Pro currently.
Best regards
Dear friend,Why not? Is this a hardware limitation or something else? Now that your UTWS5 will start supporting LHDC, wouldn't it be great if the BTA30 Pro would support this codec, as well?
The requirement of LHDC support for BTA30Pro is not high maybe because BTA30Pro has supported LDAC Bluetooth codec . Besides, adding new Bluetooth codec support is not an easy work. So we do not have the plan of adding LHDC in BTA30Pro currently.
Best regards
Okay, I understandDear friend,
Best regards
vicexxx
Also knowing the utws5 new firmware will be supporting LHDC and not LDAC makes it's very valuable for those who have utws5.Okay, I understandImagine how great you could support your own UTWS5, though, and other TWS which do not support LDAC. Is it possible, then, to add aptx Adaptive to the BTA30 Pro?
- Home
- Forums
- FiiO
