dsrk
It's targeted more towards portables at desktop grade I would say.Is the M17 targeted at the iBasso Max market? Seems like (at least design-wise) it's leaning that way.
I'm sure the K9 will be capable for PO/LO output. I you check out the much smaller and earlier made X7/X7 MK II DAP and Q5/Q5S DAC/AMPS those have 3 in 1 outputs and inputs (Line Out/Coax Out/Digital Out and Line In/Coax In/Digital In). For example I use my X7 MK II + Q5 combo with 3,5 to 3,5mm Koax cable so I can enjoy my 192KHz/24bit FLAC musics with full resolution and quality.The K9 Pro looks promising!
Will it have output switch to select between PO/LO?
Thanks for your kind feedback. Our tech team is testing about that. And would you prefer sharing your opinion about this chip with us? What is the advantage you think to use this chip ?@FiiO What about new ESS 9068 in your new lineup? I believe A&K already implemented that new chip in thier line.
That's the latest chips low power chips ES9068Q.Its been out since 2019.Thanks for your kind feedback. Our tech team is testing about that. And would you prefer sharing your opinion about this chip with us? What is the advantage you think to use this chip ?
Best regards
