FIIO’s innovative sub brand, SNOWSKY Pure Music Player ECHO MINI Is Officially Released!
Apr 27, 2025 at 9:30 PM Post #482 of 523
The lyrics switch will be added later
Cool, only thing lacking now is the eq. I mean if we can add eq preset like how we drag and drop firmware updates is more than enough if inbuilt device eq customisation is not possible. I saw the new retro eq btw, add like a custom version which reads the eq txt file and saves to it.
Apr 27, 2025 at 9:52 PM Post #483 of 523
Cool, I think there was good response for the DAC mode. Also I'm down to test it out.
Also is it possible to add an option to toggle on/off lyrics and also customisable eq?
The EQ could be great... Like maybe we could add the file with the EQ config to a folder in the device and that preset would show up in the EQ options... Would be awesome.
But also i imagine that would take a huge amount of work to do... Hopefully we can get something of the sort one day.
Apr 27, 2025 at 10:43 PM Post #484 of 523
Yup, this is the way. I got my echo unit like yesterday. The current eq settings only works for tracks on or below CD quality right?
Apr 30, 2025 at 3:08 AM Post #486 of 523
The new firmware V1.6.0 for SNOWSKY ECHO MINI is now available!​
SNOWSKY ECHO MINI firmware download link and update instrucion:
https://forum.fiio.com/note/showNoteContent.do?id=202501210934383987154&tid=17
Apr 30, 2025 at 2:40 PM Post #488 of 523
Hi everyone! I’m really enjoying the device, but I think the volume management could be improved. It’s great to have such fine increments for volume adjustments, but when using the Echo Mini with multiple output devices (e.g. headphones and then in my car via aux cable), I constantly have to jump from around 40–50 for headphones to 100 for the car. Watching the numeric volume counter go up or down with each step is very slow and not practical. Could some kind of solution be considered?
Apr 30, 2025 at 3:27 PM Post #489 of 523
So long as whatever solution can be implemented does NOT come at the expense of the fine increments - I'm good with it. Maybe have a user-selectable increment, keeping the fine increments as the default, and allowing that to be changed, in the music settings menu?
May 1, 2025 at 7:52 AM Post #493 of 523
Instead of making these cheap DAP´s, they can re release the M3 or M3 Pro as Snowsky products
I think there's a plan to release a better DAP under the Snowsky brand this year. However, given how many reddit posts I see with people buying this DAP it seems like a pretty big commercial success.
The folders will be in whatever order you upload them to the device or SD Card If you go into the File Browser... If you go to "Playlists" all Artists and Albums will be in aplhabetical order...
I tried this but it did not work. I even wrote a script that inserts them in the right order. It did not help. I will try to do it again today with a bit more delay between copies.
