FIIO’s innovative sub brand, SNOWSKY Pure Music Player ECHO MINI Is Officially Released!
Apr 20, 2025 at 8:26 PM Post #452 of 669
Sorting still not sorted on 1.5.0
Updated to 1.5.0 and was initially happy with what I saw, until I navigated to a folder of an album I purchased from an online Japanese music store OTOTOY. All their songs filenames have the number of the disc prepended to the track number, even if it's a single disc album or single, eg.
01_01 first song.m4a
01_02 second song.m4a
01_03 third song.m4a
And then with an album purchased from Bandcamp, the naming format for default Bandcamp albums is
Band name - Album name - 01 first song.m4a
Band name - Album name - 02 second song.m4a
Band name - Album name - 03 third song.m4a
Both of these naming styles obviously show in alphabetical order on a computer, but not on the Echo mini. The order seems to revert to sort by date created.
Image attached shows the Bandcamp album playlist starting with track 7.
To the Fiio team, thank you for all your hard work and addressing all the issues that have been raised so far. I appreciate your efforts immensely, but please just fix track list sorting before any more feature additions.
The processing capacity of the ECHO MINI chip is limited. We only scanned the first three characters.
If the full file name is scanned, it will be very slow.
It is suggested that you modify the file name.
Apr 20, 2025 at 8:40 PM Post #453 of 669
Apr 21, 2025 at 3:12 AM Post #454 of 669
Very beautiful :beerchug:
Apr 22, 2025 at 4:56 PM Post #459 of 669
Hi everyone, I'm new to the forum. First of all, I apologize for my English—my native language is Spanish, but I'm using an AI to help me better express what I want to say.
I see there are some Fiio staff here, and many others sharing their experiences with firmware updates. I've been using my Snowsky for over a month now and have tested different updates. I noticed most users here tend to play music by album, but in my case, I usually go to "All Songs" and hit shuffle.
During this past month, I've had many issues with the shuffle mode in the "All Songs" section. For context, I’m using a 128GB SanDisk SD card, currently formatted to exFAT, with about 2700 songs. I was on firmware 1.5.0, but shuffle in "All Songs" doesn't work properly. For example:
I play a song, and the next track is random, but starting from the second song after that, it begins playing what seems like a default playlist (meaning it's not truly shuffling, but following a specific order). If I skip through five songs and then pick another song in "All Songs," it again starts playing “random” songs—but they come in the same order as before. This makes it feel like there’s a fixed playlist after every song change, rather than real shuffle.
You can test it: play a song in "All Songs" with shuffle enabled, skip forward seven times, and note which songs play. Then pick a different song, skip forward twice, and you’ll probably hear the same songs again. This also happens after turning the device off and on. Because of this issue, I had to downgrade back to firmware 1.4.6.
By the way, I did some testing and found that when there are fewer than 100 songs in the SD card, shuffle works perfectly. But when there are 800 or 2000+ songs, shuffle seems to be broken.
Another big issue—which I believe also only happens in “All Songs”—is that randomly, when I power on the device, it starts a “MediaLib Update” automatically. This process takes around 6 minutes, and during that time I can’t use the device. It happens at random when turning the player on. I wonder if in a future update there could be an option to disable the automatic MediaLib update until this issue is fixed. (This happens on both 1.4.6 and more frequently on 1.5.0.)
By the way, I’m not the only one experiencing these problems—I've seen quite a few similar posts on Reddit. My library is on an exFAT SD card, with songs stored in artist-named folders (no album folders), and I have about 2700 files in FLAC and MP3 formats.
It would be great if you could try this on your own devices using “All Songs” and see if you get the same results. Thanks for your attention!
Apr 22, 2025 at 5:11 PM Post #460 of 669
Sometimes when I power on the echo mini it starts the medialib update automatically on mine too. Not always, just some random times, but in my case I tend to have few songs in it because I'm used to keep copied and deleted my songs from SD so it takes like 1 min. max so not much a problem in my case but I understand it could be a problem for much larger library.
Apr 22, 2025 at 11:06 PM Post #463 of 669
I will confirm and test this problem. Thank you
Apr 23, 2025 at 11:28 AM Post #464 of 669
"I play a song, and the next track is random, but starting from the second song after that, it begins playing what seems like a default playlist (meaning it's not truly shuffling, but following a specific order). If I skip through five songs and then pick another song in "All Songs," it again starts playing “random” songs—but they come in the same order as before. This makes it feel like there’s a fixed playlist after every song change, rather than real shuffle."
You are not alone! If it was happening before I didn't notice it as much but, since the last update, shuffle has not been shuffling. I also use my EM as a mini jukebox; always on Shuffle. Recently, I keep hearing the same songs every day and it is really bugging me. Starting on a different song does not make a difference.
