Originally Posted by MilkyWay /img/forum/go_quote.gif
Oh yeah maybe when I'm done with the mods we can compare our Dx000's to see how they stack up against each other.
Sure, that would be very interesting to see how much of a difference there is (or isn't)!
I found I could hear a slight rattle in the driver assembly if I shook it by hand fast enough along the axis of the driver, which suggests something mechanical rattling inside somewhere - and that the shaking induced by the low frequencies is the trigger.
I spent a couple of hours going over the driver assembly as carefully as I could. I pulled out a few tiny particles from the grille and one or two hairs (but I think they may have been introduced by the inspection process). I also tried a tiny computer vacuum cleaner. I couldn't see anything obvious on the grille, in the uncovered holes in the back of the driver, by shining a light through it from either side, or by looking at the driver surface through the grille with a small magnifying glass. There are parts of the grille that don't quite mate with the surrounding black plastic, but it looks like glue binds the two together and I didn't seem to be able to induce any horizontal movement (and shaking orthogonal to the driver axis didn't seem to rattle either).
I don't think there's anything else I can accomplish.
I've put them back together and am listening to some music (straight out of my crappy PC analog output) which still sounds pretty good, especially after listening to my old headphones for a couple of days
I'll cross my fingers and avoid anything with really low tones and see how it goes for a while. I imagine getting a driver replaced on a modded headphone could be a PITA - just sourcing the driver assembly could be a challenge or expensive or both. Fortunately I listen to a fair bit of acoustic jazz and I know the lowest note on acoustic bass is just over 41Hz which is safe so far!
