WindowsX
Member of the Trade: Fidelizer Audio
- Apr 27, 2007
So here's your cue @WindowsX--KeithEmo has pointed out that a PC will generate significant amounts of jitter on its S/PDIF coax or optical outputs, and these can be read directly (as opposed to USB audio)--why not directly measure jitter on these with Fidelizer on and off instead?
It's possible with audio interface having digital input/output to perform closed loop recording. I'm not sure if that is possible, maybe we'll need two audio interfaces? I'm not sure.
Anyway, it's not like I have such devices at hand to perform this nor any device will work. I used to have RME Fireface 400 but it's broken not so I can't test it myself anymore. Maybe someone can take it from here following my examples for real world data. But I doubt you'll find something audible with analog metrics.
But you didn't measure anything audible, and besides which, as soon as it has to be time-aligned, it's no longer completely bit perfect.
It'd be crazy if you can measure anything audible in pure software environment. It's all in virtual sound card. You should be surprised that I can even measure something out there to show you here.
By the way, how can you measure different recording files without time alignment? Aligning doesn't break bit-perfect because audio stream aren't altered in anyway except choosing where of stream to compare. There might be some rounding error to consider like I said before but all measurements showed 0 dB so it's all good.
Well, it seems to be only me who took actions to find out. I hope someone will run the similar experiments to share with us soon.
Regards,
Windows X
