joseluishs
Hehe thanks! I use it like this:I'll buy your old one . Out of curiosity, how are people connecting these to a source? Just USB c to a PC or what? I2s somehow?
Computer —USB — RME Interface — AES — Wandla
Hmm, makes sense I guess. Though my brain keeps asking what the point of going from USB to an RME is. Why not just use the USB c then? I'd like to figure out a way to do i2s since it's supposed to be really good, but USB to i2s seems pointless vs USB c. Not sure I can get a pink faun to work with the wandla eitherHehe thanks! I use it like this:
I am using all the digital inputs of the Wandla. The USB C is connected directly to the computer. All the other digital inputs of the Wandla (Optical, Coaxial, AES, I2S) are connected to the Matrix X-SPDIF 2. All the digital inputs sound the same to me. Sadly my hearing isn't what it use to be but I could hear slight differences between the digital inputs using the iFi iDSD Pro, especially between USB, I2S and Optical. Optical sounded more organic, smoother, less fatiguing. I2S seemed to have more attack on transients compared to USB and Optical. Sometimes I wish I would have kept the iDSD Pro and sold the Wandla. Hopefully the Golden Sound edition will make me glad I decided to keep the Wandla.I'll buy your old one . Out of curiosity, how are people connecting these to a source? Just USB c to a PC or what? I2s somehow?
Thank you for the interesting questionHmm, makes sense I guess. Though my brain keeps asking what the point of going from USB to an RME is. Why not just use the USB c then? I'd like to figure out a way to do i2s since it's supposed to be really good, but USB to i2s seems pointless vs USB c. Not sure I can get a pink faun to work with the wandla either
I would try a different usb port on the pc if you haven’t. If it’s plugged into a usb 2.0 port then try a 3.0 port. Try reinstalling drivers if you haven’t. See if anything on the pc is trying to take exclusive control of the dac maybe when it happens. Just a few guesses. I would also set the dac to 48/24 in windows instead of 32.Recieved my Wandla last week and really enjoing it!
A huge upgrade over my V850.
However, I have a strange Issue which I can't quite reproduce yet.
I use the Wandla connected to my PC via its included USB cable. I have the Windows driver (v1.2.0) installed.
Afte a random amount of time, for example when playing a game or having a Zoom conference call, the Wandla just freezes and plays a static noise on the left channel.
The touchscreen is inresponsive. I have to unplug it from power and then reconnect it, then it immediatly starts working again.
I have Windows set to 48kHz/32 Bit, as many games are mastered in 48 kHz nowdays.
I have performed a factory reset via the Wandla OSD, no change.
The Wanlda I recieved is fairly new I believe, as I had to wait quite a long time for my retailer to recieve a restock.
Mainboard Version 4.0, FW Version 1.3.0, Serce Version 3.0, Bootloader Version 0.13.3.
Has somebody experienced similar issues?
Edit: I will try to play Tidal in Exclusive mode for a long time to see if it still freezes.
I have connected the Wandla to a USB 2.0 Port now. Also I have changed the Windows Sampling Rate back to 44.1 kHz with 32 Bit, which was the default as far as I remeber. Will report back, if the issue reapears.I would try a different usb port on the pc if you haven’t. If it’s plugged into a usb 2.0 port then try a 3.0 port. Try reinstalling drivers if you haven’t. See if anything on the pc is trying to take exclusive control of the dac maybe when it happens. Just a few guesses. I would also set the dac to 48/24 in windows instead of 32.
I have also noticed that Wandla likes to be connected directly to the usb c ports in my MacBook, it doesn’t like being connected to an external usb hub or things like that.Recieved my Wandla last week and really enjoing it!
Is there FW 1.3.0 available? Mine is still 1.2.0 and no updates.The Wanlda I recieved is fairly new I believe, as I had to wait quite a long time for my retailer to recieve a restock.
I have. I've had my Wandla for about little more than a week. It has frozen twice, so far only on optical. One was silent, the other was with a loud high-pitched noise, both had unresponsive touch screen. Also with 1..3.0 and m/b v 4.0.Recieved my Wandla last week and really enjoing it!
Holy crap, I have an Adi-2 Pro and a Wandla as well and this never occurred to me to try. Even a Mojo 2… I might really just copy your setup thereThank you for the interesting question
The thing is that the RME ADI-2/4 Pro SE is a monster digital device. I use it for recording with Logic Pro as well.
But mostly because the RME can store many settings for my headphones and transfer them digitally to the Wandla. I can save EQ and the lowest cross feed to the Wandla and switch settings with the companion app in less than 2 seconds. And at the same time it can send optical to my Mojo 2 with the same information.
Also, I find the Wandla to sound better with either AES or optical. I don’t have i2s to try it out
Thats exactly the behaviour I am facing! So it seems to be a FW glitch of some sorts.I have. I've had my Wandla for about little more than a week. It has frozen twice, so far only on optical. One was silent, the other was with a loud high-pitched noise, both had unresponsive touch screen. Also with 1..3.0 and m/b v 4.0.
What Wandla FW/HW are you running?Holy crap, I have an Adi-2 Pro and a Wandla as well and this never occurred to me to try. Even a Mojo 2… I might really just copy your setup there
The newer units with HW 4.0 seem to ship with it. Do you have the option to switch between Pro and Red Book under Audio -> DAC Out Standard? I think they added the ability to switch between those via HW in 4.0, so the Max Output voltage gets capped at either 4.0V or 9.75V without analog/digital attenuation.Is there FW 1.3.0 available? Mine is still 1.2.0 and no updates.
