How do you set up the Singxer su6 with i2S output to Wandla ? Wandla couldn’t read the DSD file at all when I use Singxer su6.I run mine off of the singxer su6 i2s and it is slightly better. Not a huge upgrade like some other dacs but noticeable. I’d be totally happy running it off of coax.
Ferrum WANDLA - Impressions Thread
- Thread starter XERO1
kingoftown1
- Jun 19, 2011
powering the singxer with a hypsos improves things further
Thank you. So from your own experience a DDC is not worth it?slightly cleaner transients and spatial information. But it’s very subtle. Changing the filter makes a much bigger difference.
gonintendo
you want the psaudio setting here
I haven’t tried wandla’s usb input, but if you have a good coax or aes transport then probably not.Thank you. So from your own experience a DDC is not worth it?
Hi Gonintendo,
After adjusted Su6 i2S switch with PSaudio setting , my Wandla still couldn’t read DSD file from Roon.
Do you any other setting for this circumstance?
Thanks in advance
gonintendo
ah you might need to mess with the dad specific switches. sorry I don’t use dsdHi Gonintendo,
Thanks in advance
wallaby1170
I'll have to give that a try. Thanks for the suggestion.If you use it with the Hypsos, you can tune that - the range is 22-30V, standard setting of 24v sounded aggressive to me - 22v was perfectly smooth, so you have a lot of headroom into piercing treble that would make my ears bleed.
Louisiana
Hi Gonintendo,
it looks like you have to change the device from DoP to nativ dsd.
Settings -> Audio -> Device setup.
For those who want to try the I2S input with a better clock signal, it would be important to know what does the Wandla use for the internal clock.
Is it an ocxo, tcxo, femto clock? Can't find info about that in the specifications..
Lakerfreak
Hi, if anyone has a stack of Wandla, Oor and Hypsos, could you show me a photo of how they are connected? Do I need to purchase an additional cable from Ferrum to connect these three? Thanks in advance.
mitch751
- Feb 8, 2010
You just need this https://ferrum.audio/product/power-splitter/
Meanstreak242
I have all 3. You need that splitter AND an extra power cord. The Hypsos comes with one, the splitter comes with one. To plug in the third device you'd still be one cable short. (I Had to buy the splitter and one extra cable.)
Iirc mt stack came with two cord. I believe all i bought was the splitter.I have all 3. You need that splitter AND an extra power cord. The Hypsos comes with one, the splitter comes with one. To plug in the third device you'd still be one cable short. (I Had to buy the splitter and one extra cable.)
Looking at my invoice, I had to buy an extra cord. Hypsos had one cord, splitter had another, and I bought one to hook up the Wandla.
wagninger
Member of the Trade: Level Audio (Italy)
Since others already stated that you have to buy the splitter plus extra cable, this is what that looks like.Hi, if anyone has a stack of Wandla, Oor and Hypsos, could you show me a photo of how they are connected? Do I need to purchase an additional cable from Ferrum to connect these three? Thanks in advance.
Total: 10 (members: 4, guests: 6)
