One thing must also be mentioned.
According to Feliks, putting 4 KT88 tubes on the Euforia is not intended.
Feliks recommends using the tubes listed in the manual.
Of course it is possible to use 4 Kt's, but I think that was the weakness of the Euforia if I remember the old reports correctly.
This is also due to the fact that they are quite close to the upper limit in terms of amperage.
I would be careful with the hi-fi dealer, if he knows that you are doing things that are not in the manual, he can refuse to repair them.
Even an exchange if you are still in it.
Take out two KT tubes and replace them with a couple of 6SN7 and see if it improves.
What you should also keep in mind in the future is that a set of 4 is also matched.
It can be that 1-2 tubes put too much strain on the bias control.
Usually one tube is enough and the drama is perfect.
You can check if one of the tubes hums when there are two 6SN7 in the front.
Plug in two Kt 88 and leave them in for 30 minutes, then switch them off, wait a bit and put in the next pair.
If only one channel is humming, mark the tube.
By the way, I also use adapted 6V6 tubes,
They also hum a little but not so much that it interferes with the music.
Of course you shouldn't do it but some 6V6 are better than 6SN7.
