barontan2418
Hi bt.
Looks like you've done the correct wire mod, so it should be OK. Do the heaters light up? And do the pins manage to go well down in the socket? If not, this would also stretch the anode wire a bit, especially as the 39's base is larger than the 38's. And pins are clean, of course?
And now I see you find the same thing @ZRW0 ...this is beginning to have me wondering just how Mrsx has configured her adapters!! I shall
h ave a go at trying to replicate what they might have done and find a solution, as well as ask them to send me info on their layout. So it might be best to wait until I find out what's happening here...CJ
Hi H1. Yes both valves light up perfectly and they are flush with adapter. My first thought was pos adapter was configured differently. I have no issue with top adapter not reaching ok. Thanks for help.
Also if I replace either EL39 with EL38 the side with 38 produces sound all be it very quiet the 39 side no sound.
