connieflyer
- Aug 23, 2012
Been a long time since I have heard this!
Hi pct,A while back I wrote about the great SQ results I was getting with EL11/12 combo. Yesterday the EL12 spez pair I ordered from Germany arrived much sooner than I expected. I put them in the adapters I already had from Mrs. X, which includes the “octopus” cable for the top connection. I was immediately met with a horrible hum. That was easily solved by touching both adapter cables but that didn’t seem like a viable long term solution!!!
I then put a 5mm ferrite choke I had ordered from Amazon on each adapter cable. That was a little tricky. The chokes came locked without instructions of how to open. After a little effort though I got them open. I had to wrap each adapter cable with some aluminum foil to get a tight fit. That helped with the hum, but it was still completely unacceptable.
Then I remembered from the earlier spez discussion on the Elise thread that the positioning of the headphone cable was important. With a little experimentation, I was able to completely eliminate the hum. Suddenly, there was absolute QUIET, even with Euforia volume cranked up to maximum (without music playing of course). It was like an ancient graveyard in the wee hours of the morning.
This combination, in my system and with my ears, is now my unqualified holy grail for Euforia. It takes Euforia to a level I could not have imagined. Highly, highly resolving, but on good recordings, musical and magical.
This is not a euphonic or colored combo. It will not compensate for bad recordings. To me it is as close to neutral as I have ever heard with Euforia or Elise. I’m sure there are amps that can achieve more, but I can’t imagine what qualities they would add to improve on what I am hearing.
As far as I know, @hypnos1 and I are the only two who are using this combination. And H1, with his dexterity and knowledge, has set up his tubes in a special way. I suspect few others will try this combination. EL11s and EL12s are not for the faint of heart. People have reported buying tubes that were DOA or failed quickly. They all require adapters, and the spez requires a special adapter with the cable. But I am confident anyone who can get to the point I’m at will not be disappointed. In fact, I am sure they would be thrilled. And I have no reason to believe this would also be true with Elise.
This is a picture of my current set up. The medal headphone stand is actually part of the hum solution. If I move it, the hum immediately returns. And if I put HD800S on it, the hum returns.
Hi pct,
Which brand did u get of the EL12 Spez?
I am unable to reach CF via PM.....Mordy: If you buy that pair and don't like them, @connieflyer will buy them from you and give you my address so I have an extra pair
