Tunkejazz
- Apr 4, 2015
For years I have used a Mtech Hiface2 that converts USB to coax. It has galvanic isolation and it works great. I think I got it (4 years ago?) for 150 eur if I remember correctly.
Coax and optical aren't the same thing. Coax uses a wire instead of an optical fibre but the protocol they use is the same. I use an X5iii or an X3i outputting over coax into my Bimby sometimes. I believe some people have issues with high-bitrate files with the X5 but I've not had any problems with redbook - but I'll try it again and make sure if you are interested in that route.I did buy the e i t r it would not work for me it kept coming up with an error that it could not find the Cmedia device I'm using Windows 64 win 7. I sent it back for refund. I am not the only one that has had this problem you can Google it I would assume. The device I'm looking for is a Dap it's a music player portable and it has coax Optical output as well as headphone output. I would just like to have a source that did not have to be turned on or viewed instead of using the PC I thought I might like to use this device astell & Kern very good manufacturer but I didn't want to spend too much on a device like that either
I thought you did know - I was more protecting myself from ridicule for recommending the X5 if you specifically wanted opticalI am aware of the coax and Optical are different but both of them are digital signals and can be outputted from the same Jack. The Asus Essence audio card that I'm using has a digital output Jack you can plug in either a digital cable coax into the port or with a small adapter plug you can plug in an optical cable out of the same Jack it's a digital signal that goes down whether it's a wire or glass. But it wasn't just that particular signal that I'm looking for that was a big plus I'm looking for the music server player in particular. I'll look into the X5 and see how that one measures up also have not used a music player except for a Cowan J-3 that still works but has limited functionality compared to what I'm looking for. Thank you
Hi H1, The discussion about "sinergy" between DACs and tube amps, specifically the Euforia in this case, promises to be a very interesting one. I admit not having the chance yet to hear a Chord Hugo, but know is regarded among the best in its price range. The FPGA architecture, strictly speaking, means that the decoding algorithm of the DAC is upgradeable via software, which is indeed a very desirable feature. Some of the very best DACs do have this function, pioneered by the great Theta DACs. The Schiit Iggy (as I understand) is a modern descendant of the Theta, but much more relevant than this feature in terms of SQ is the decoding format, (and of course the implementation of the analog output) simplified around the current discussion about delta/sigma (the vast majority) vs. multibit DACs.
And I say simplified, because true multibit DACs were abandoned many years ago by the industry, they were very expensive to manufacture, needing a precise laser trim on hundreds of "ladders", and only recently, audio manufacturers identified a renewed demand for multibit DACs, so they hurriedly implemented specific industrial multibit ICs for audio purposes. Some with great success, like the Iggy. But, how they compare against true multibit DACs, expensive, hand trimmed, made exclusively for audio many years ago, and never made anymore ? Interesting question, and in many ways similar to NOS versus current production tubes. In fact, there is a cult following around pieces like the UltraAnalog 20400A, a multibit module made up to 1990 or so, which is, truly, the GEC of all DACs !! This one was used in the absolute top high end DACs of the time, among them the magnificent Spectral, and their current production at nearly 20k a piece, still uses it, as I understand. Kind of a NOS DAC, if you want. More modestly, my Parasound DAC 2000, 1990 vintage, also have this one, have compared it with quite a few much more modern DACs, and while you can say that this or that one are maybe better in some aspects, none of them even comes close against its utterly analog, un-digital, expansive sound, or its ultradeep, room shaking bass. Now I understand the cult. And this DAC just sings with tubes, as you can imagine. Anyway, this suggests that perhaps all the new technology does not necessarily offer better audio, as the industry want us to believe. And come on, we collect old tubes, so we now that.
No need to protect yourself against ridicule from others. This is a forum of ideas and people have different ideas and they're all worth exploring. I appreciate the fact that you would even answer the thread and I will check into the X5. Myself I am not afraid of ridicule usually that comes from small-minded people and I'm bigger than that. Thank you very much
12SN7 Sylvania (3 hole bad boys, sound the same as 6 volt i have in hand) sound sweeter and refined. Great resolution and strong bass.
I'm confused. Does the Sylvania 12V version sound better or the 6V Sylvania version better, or both the same?
