Great points! Absolutely true, it's now readily available (even more so in europe), it's easily under 10k€ (unless you opt in for a special version and / or tube roll a lot), and there are a lot of impressions to read because it's a lot at shows or dealers, so you can probably hear it yourself. It's price is also fixed and won't fluctuate like with the AIC-10. It's also not extremely big and looks stunning and there are different wood types for you to choose from. If you want to demo it and test it for yourself, you probably will find a way, at least with the Full Music tubes. This won't happen for the AIC-10 and other rare amps, and there will always be that uncertainty and "black magic in a closed box for an insane price"-factor which can easily be a deterrent, but it could also on the other hand have that "mystic" factor of the unknown that draws attention, because the price went up, because it gigantic, because people rave about it, etc.
I think the Envy has truly more than enough power for everything except (probably) two headphones, which are also powered well enough for most people with the Envy, but those two just do not reach their utmost limit and will scale further if you give them even more power. I said it before, i'll say it again, people run OG Susvara / Immanis basically on a speaker amp with the AIC-10 from its back outputs.
