Doug2507
How do you find RCA red base vs kenrads with the MO's?I always end up putting the Melz back in after some time but I quite like them.
I'll have a compare a little later.How do you find RCA red base vs kenrads with the MO's?
No rush, just whenever.I'll have a compare a little later.
I think I like the Ken Rads better with the MOs.How do you find RCA red base vs kenrads with the MO's?
Why, they're the same tubes for triple the price? I've had 2 different sets myself, both identical in sound to each other and the stock ones, though the Reserves are worse sounding until burned in.Id like to replace the Psvane CV-181 mk2 (6SN7) with the Ray Tubes 6SN7 RESERVE is it worth, i like the shape of the tubes like to keep that but dont now if its worth the upgrade? Using the Envy Performance Editon
Oh what tubes did you go with? Maybe I can give them a try. Was it the Elrogs that fixed your issue?I do have a caldera that I do use with my envy...I have found issues of hum and noise are very dependent on the tubes you use...I have essentially eliminated my noise issues with different tubes...I find the envy very sensitive to tubes and to power issues...experiment and you might find you solve your issues...the sad truth is that with very easy to drive HP's you may need low gain
Your hum issue sounds a little bit different than the one I had. I could slightly hear the power transformer hum without headphones if my ear was close to the transformer. When using low sensitivity headphones like Susvara, I could not hear the hum through headphones with or without music even with volume turned all the way up on LO, MED, or HI gains.Hi everyone, I’m now an owner of a Feliks Envy Performance! Woo I’m unfortunately having an issue though with hum.
I have a pair of ZMF Atrium headphones which have an impedance of 300 ohms, so it looks like medium gain is recommended. However, on medium gain I have a low 60hz hum that is very much audible but not loud. It does not change as I increase the volume, but if I turn the volume knob past 50% I start hear new hums (way way way louder than I could ever handle listening to. On medium gain I have it at 10% volume) that do get louder with volume increase.
On low gain though, there is no audible hum until I get to about 80% volume.
I also tried my Meze Elites. These are very low impedance planers and so I use them with low gain and have no problems. Just out of curiosity I tried medium gain without playing any music and the hum was even worse than with the ZMFs. No real worries there though, they are designed for the medium gain setting anyways.
Does anyone have advice or have ran into this problem? I can use the ZMFs in low gain and 25% volume just fine but they do lose a bit of emphasis in the bass, and I’d prefer to use medium gain if I can.
Edit: I am using the amp with the included power chord and an Emotiva cmx2 AC Line Filter and an EBTech HumX. I did try different power outlets, connecting directly to the wall straight to the Envy, going through a Furman power conditioner, with and without the HumX, and all had the same problem. With or without any inputs connected made no difference.
the elrogs definitely helped as did the rca 5692...I suggest you experiment...tube amps are finniky coming from all SS it took me a while to figure it out and I am still learningOh what tubes did you go with? Maybe I can give them a try. Was it the Elrogs that fixed your issue?
