Real Gentleman!It was actually a wild woman!!
But still my fault, I should’ve explained in more detail how to remove. But she has changed tubes for me in the past. I haven’t told her the cost, she would be upset.
Next time I have power tubes replaced though, a thick towel is going to be placed on the transformer. Hindsight is a great thing!
Feliks Audio ENVY
- Thread starter Deceneu808
Still sounds a bit disconcerting to me (see link below - the 14 second clip). The bouncing blue glow in the left tube is accompanied by high speed clicks (in time with the flickers). The clicks end up really fast until they do eventually subside.Thanks.
The left one (with the blue light also in the middle of the tube) pops very rapidly on warm up. The pops are in time with the blue light "flickering". After about 5-10 minutes it has settled down though.
I did speak to WE and they said if they sound fine then they just need burn in so don't worry.
They said I can RMA the tube if I am worried though so good customer service there.
I guess I need to just burn them in and I'm just a bit paranoid after my power supply failure![]()
The normal clicks and dings of a tube warming up are fine and also present. The right tube is just lit up at the top and warms up in a more expected manner...dinging normally as you would expect like a grandfather clock
https://1drv.ms/f/s!Am1sqoykcyZHg6hGEnYB4v2ezxhhkQ
If others can confirm the same behaviour with these WE tubes which subsides over time with burn in then my mind will be at rest. Otherwise I may RMA this one tube.
Note the Microwave was on a few rooms away so that's what you can hear plus some random Netflix rubbish my daughter is watching
The new Brimars are so sweet sounding, also with a pure black background. I will probably get the other pair of the guy that sold them, he also has Tung Sol 6SN7GT Round Plates. The Linlai do sound sterile and analytical compared to the Brimars, but they have more seperation and soundstage.
Neither of my new WE’s exhibited this behaviour.Still sounds a bit disconcerting to me (see link below - the 14 second clip). The bouncing blue glow in the left tube is accompanied by high speed clicks (in time with the flickers). The clicks end up really fast until they do eventually subside.
Note the Microwave was on a few rooms away so that's what you can hear plus some random Netflix rubbish my daughter is watching. Normally when I have a session the house is completely silent
Are 6SN7 adapters (socket savers?) clever and helpful if you want to swap the tubes out, say, 2-3 time per week to minimize the wear?
nwavesailor
- Nov 14, 2009
Some folks are purists and anything added (socket saver) is a negative. I am not in that camp and it can't hurt to use them.Are 6SN7 adapters (socket savers?) clever and helpful if you want to swap the tubes out, say, 2-3 time per week to minimize the wear?
Most definitely. These (imo) are the best but a little pricey:Are 6SN7 adapters (socket savers?) clever and helpful if you want to swap the tubes out, say, 2-3 time per week to minimize the wear?
https://wooaudio.com/accessories/various-tube-adapters
2 x 8-Pin to 8-Pin
normie610
Does the clicking (or popping) sound also appears on your headphones? I had one faulty WE300B tube, with a similar flickering behavior, where I can hear popping sounds on my headphones repeatedly, in sync with the flickering motion in the tube (however, no sound coming out of the tube itself, only through the headphones). Spoke to WE about it and they told to me to send it back to them to have it replaced. They suspected that the tube had a gas leak. Perhaps you can email them and see if they think it’s damaged/faulty.Still sounds a bit disconcerting to me (see link below - the 14 second clip). The bouncing blue glow in the left tube is accompanied by high speed clicks (in time with the flickers). The clicks end up really fast until they do eventually subside.
Thanks, the Woo Audio stuff is US, so i will most likely just talk to Deyan since he is EU and gets recommended a lot.
Yes exactly that. The flickering corresponds with the popping in the headphones.Does the clicking (or popping) sound also appears on your headphones? I had one faulty WE300B tube, with a similar flickering behavior, where I can hear popping sounds on my headphones repeatedly, in sync with the flickering motion in the tube (however, no sound coming out of the tube itself, only through the headphones). Spoke to WE about it and they told to me to send it back to them to have it replaced. They suspected that the tube had a gas leak. Perhaps you can email them and see if they think it’s damaged/faulty.
It's funny I think I've been reading your thread on headphones.com where you describe this
I think I'll RMA it but I have contacted WE as well. Of course they are happy to replace it but I am curious what they say when they watch that small clip I posted.
Cheers
Yes his are absolutely fine as well but the Woo ones are ceramic and really sturdy.Thanks, the Woo Audio stuff is US, so i will most likely just talk to Deyan since he is EU and gets recommended a lot.
I bit the bullet and paid a little import tax and I am pleased I did.
normie610
Yes it was meIt's funny I think I've been reading your thread on headphones.com where you describe this. It's the same phenomenon for sure.
ThanatosVI
Deyan has different "models", I really like his Aluminum Adapters, they look and feel very premiumThanks, the Woo Audio stuff is US, so i will most likely just talk to Deyan since he is EU and gets recommended a lot.
Langrex replaced my Fivre tube which had one less pin with no fuss.Yep, I use the same Deyan ones for both (and other 6c5 & L63)
Yeah those are the ones to get. My brown base aren't from Langrex but are more quiet than the black base I have from Langrex, so in case the base rather than the purchase source is it, I'd recommend the brown base. They've been among my favorites on the Envy and my OTL. On the OTL especially they seem to widen the stage but they bring very good and clean bass on both.
I plugged them in though and it sounded like an aircraft taking off. Wow the noise. Scared the **** out of me.
I guess I was unlucky as you mention some of the Fivres are noisy. I think I'll return them as it might be tricky to find four quiet tubes. Two is easier but four is more difficult. I went through 6 until I found 4 Brimar 6J5G that were dead silent.
Shame as I was looking forward to hearing them.
I'm also RMA'ing the WE300B which appears to have issues will gas (don't we all).
Yikes, well I've never heard anything like that from them. I think more like a little hiss. Bummer regardless, especially the WE300b.Langrex replaced my Fivre tube which had one less pin with no fuss.
Total: 11 (members: 0, guests: 11)
