Feliks-Audio ELISE...(previously 6SN7 + 6AS7G/6080 prototype)
Sep 19, 2015 at 9:42 AM Post #2,928 of 3,428
And I just want to remind folks that tubes with loose bases can be great buys. I was so blown away by the Cossor GZ37 that I wanted to get one more for a backup. Found this tube outside of eBay for a very good price. However, the glue bond had completely failed. The only thing holding the base to the bottle was the soldered wires. The vendor was using the fat pink rubber band to hold it together, but still, too wobbly and fragile for daily use.
The first thing I did was grab two long rubber bands and use them to hold the bottle firmly to the base. And only then did I plug it into the amp to make sure it was OK. Since rubber is an insulator, no worries about shorting pins, and the rubber bands are thin enough that the tube could be seated firmly into the socket. But of course, I wanted to make a more durable repair. For this, I used clear finger nail polish. I applied it to the glass-base junction and then put the tube aside to allow the polish to harden. And it is as good as new! :)
Sep 19, 2015 at 12:16 PM Post #2,930 of 3,428
Roger that, Colin!!
Now here is THE question...is there a Driver tube that could be selected,  that would fatten up that bottom?
Hi JV.
Hopefully I have some good news for your 'oldie' 6N7Gs...with any luck they might echo my FDD20s - happily (and I should have known better, lol!), with a few more 5 hr sessions on them they are coming along VERY nicely indeed : bass is developing in both extension and impact. Detail is also becoming more apparent. And soundstage is opening up a treat...they are beginning to run at the Mullard's heels!...
...they are just taking a bit longer to catch up!!
So I can only hope your joybringers develop in the same way...
Can anyone tell me where I can order this and how long and price. All black unit. (Looks damn good.) Also is this running Class A and can it handle low impedence headphones?
Hi SOS, and welcome...
My best advice would be to email Lukasz at  :  info@feliksaudio.pl
He will give you all the info you look for.
The stock price is $649 + shipping...but if you want to use your own tubes, just ask for a price without them.
The Elise has been configured to handle low-z cans better than most OTL amps normally do - and Shaffer has had good results with such.
Wait time has recently been 7 to 8 weeks due to delays/holidays, but best to check the current status with Lukasz.
Best wishes,
CJ
Sep 19, 2015 at 12:41 PM Post #2,931 of 3,428
Sorry about the rambling below, but I really owe this thread a few posts, and this is the first chance I've had to post for a while....
I seem to be cursed when it comes to getting some quality time with my Elise. Firstly, I lose my job the day I was going to place my order  - and end up ordering it just before the price increase, with fingers crossed that the interview I had that morning went as well as I hoped (it did, fortunately). And now I've broken my foot, thereby disrupting my plans to make a proper space for the Elise where my “nice” gear sits.
The net result of all this, is that I feel derelict in my posting to this thread, and I have only had a few hours listening with the Elise - and then only with my portable sources (yes, H1, the X3 has been pressed into emergency service again!).
With my new job, I have a much longer commute, and much longer hours, so I’m not going to have enough time for any serious tube-rolling. Therefore I’ve elected to stick (so far) with just trying driver tubes which are currently in production. I have the stock drivers, some Tung Sol re-issues and some Electro-Harmonix (not the gold ones).
I won an ifi micro iCAN in a forum competition and I liked it so much that I got a complete ifi stack to celebrate when my new job was confirmed (as you can see in my avatar). I got a bit worried at this point that the Elise would end up disappointing because I *really* like the ifi, and also because ifi goes to extraordinary lengths to suppress noise - to the extent that even the power supply has active noise cancellation built-in! Any hum or static from the Elise was going to be a black mark against it. My Little Dot has never been noisy, but silent it was not! So I don’t really expect a black background from a tube amp. Well, when I turned on the Elise, I thought it was broken - the silence was deafening! No hum, no static, nothing. So, step one passed
Next, how does it sound? Well, at first listen, with the stock drivers, it was a little disappointing - after the high expectations and the long wait to get it. There was nothing wrong with it (apart from the usual slight roughness around about the frequency where you get sibilance - which I always get with unburnt in tubes) but it wasn’t *special*. Kind of like the O2 - totally competent but lacking in “magic” or character (in the case of the O2 this is a good thing, but it isn’t what I want from my tubes!). I’m pretty sure that some burn-in will bring out the magic in the stock tubes, but I had the Tung Sols already waiting. Time to pop them in.
w00t! Magic in abundance! The bottom end filled out, and so did the “tubiness” I love. My AKG K702s never sounded so good!
A day or so later, the EHs arrived. And, again, magic aplenty :D. The K702s became a bit too bright, in comparison, but my HD600s were perfect.
So, Tung Sol for the AKGs, and Electro-Harmonix for the Senns. I couldn’t be happier
. Both sets of tubes have the lush mids that I look for from a tube amp, and both have a good solid punch to the bass without any leakage into the mids - another thing I look for. But the EHs are more forward at the top end - which suits the Senns, but are a bit much with the naturally brighter AKGs. I slightly prefer the Tung Sols overall, because they amplify a little less, and that puts the volume control of the Elise more into the sweet spot at the volumes I listen at. Most people listen louder than I do, so YMMV. Also, I plan to use the AKGs more with the Elise, and the Senns with the ifi, so the synergy with the headphones works a little better.
Bear in mind that *nothing* is burned in yet, and that my source was just my, albeit very good, portable player, and things can only get better.
The really good news, is that the Elise can sound fantastic without exotic tubes. Anyone with limited time, or a limited budget, will still get excellent results with the Tung Sols (which are now the stock drivers, I believe). And the EHs also give excellent results so for very little extra expenditure you can get two amps for the price of one (signature-wise).
Edit: Just found this comparison which includes the TSs and EHs. I pretty much agree with everything he says (but in the context of the Elise), except that I liked the EHs a *little* better (with the right headphones): http://singaporehifi.blogspot.co.uk/2011/02/6sn7-comparisons.html
Sep 19, 2015 at 1:25 PM Post #2,932 of 3,428
Hi JV.
Hopefully I have some good news for your 'oldie' 6N7Gs...with any luck they might echo my FDD20s - happily (and I should have known better, lol!), with a few more 5 hr sessions on them they are coming along VERY nicely indeed : bass is developing in both extension and impact. Detail is also becoming more apparent. And soundstage is opening up a treat...they are beginning to run at the Mullard's heels!...:wink_face: :D ...they are just taking a bit longer to catch up!!
So I can only hope your joybringers develop in the same way...:L3000:
Hello H1 -
I think the Joybringers are the kind of tube that reveals just what the source has to offer. If I listen to a recording that has great bass, that is what I get. If the original recording was lacking in bass punch, the Joybringers deliver the news.
I have done some more comparisons to C3gS, with both drivers C3gS and then Joybringers, in my system, I definitely prefer the Joybringers. They are better in this amp, to my ears.
Monday I will get the 2nd pair of 6N7G's and we will see if all of them in the ST envelope 6N7G's are good, or if my French made pair just happen to be special.
I am loving my Joybringers and they have renewed my music collection. Selections that I barely glossed over before...I now am transported, enter the room at the place and time the recording was made, and sit amongst the musicians. I way better understand why and how the recording was made. the original motivation and inspiration comes through.
Again, the Elise, with Joybringers drivers, is not a headphone amp. It is a spiritual transportation device that picks you up and and takes you to the place, time and very moment that the recording was made.
Could not be more pleased. Hate it when I have to 'come back' from my musical excursions. :-)
Cheers
--JV--
Sep 19, 2015 at 1:37 PM Post #2,934 of 3,428
Very nice post tjw321..
So glad for you on the new job. Congrats! Long commute stinks, but better to have a job than not, 'eh?
Broken foot! Wow, now that is bad luck but then you won that cool rig in a forum competition!
Never a dull moment in your life :-)
Glad you have the Elise and are enjoying. Hope you can squeeze in some more listening time. You will be rewarded with each listen.
Luck to you, sir...I am off to follow your link and read the blogpost Elise opinion.
Cheers
--JV--
Sep 19, 2015 at 1:37 PM Post #2,935 of 3,428
Speaking of music, just discovered David Gilmour's new album, "Rattle That Lock". As one would expect, there definite hints of Pink Floyd and I'm liking it a lot. :)
I was wondering about the album. Typically, he's good for one of two key tracks, and the rest is kinda filler. Ironically, my favorite track of his is not on an album; it's a flip side of a 45RPM 12". Killer sound, too.
The new tubes for the Woo have arrived! Rolled a pair of 6CY7 about a half hour ago, still barely warmed up, and the signs are encouraging. First good sign, no buzz.
Sep 19, 2015 at 1:38 PM Post #2,936 of 3,428
I just downloaded the deluxe version in flac this morning....I got it from melodishop.com
$1.26 for the deluxe flac version...it has four different mixes of Rattle The Lock ....great album....I am listening to it for like the third time
Sep 19, 2015 at 1:57 PM Post #2,937 of 3,428
A dollar twenty six cents for a set of FLAC files for a newly released album?
That is extremely inexpensive.  I did a "whois" for melodishop.com and it comes back as Ukraine domain,  I wonder if they are selling legally dispensed copies?
Interesting article here, about FLAC files with a link at the end,  to get a progam that looks at the FLAC file and determines it's origin (FLAC from CD, FLAC from MP3 etc)
Would be interesting to see what it reports on the FLAC's you downloaded from melodishop
http://www.theguardian.com/technology/askjack/2012/jun/14/digital-music-flac-sources
--JV--
Sep 19, 2015 at 2:03 PM Post #2,938 of 3,428
--JV--
You can not get a flac from an mp3
Sep 19, 2015 at 2:35 PM Post #2,939 of 3,428
Hello Whirlwind -
You can...it does no good to do so, the resulting FLAC will sound exactly like the source MP3.
Point is,  that its doubtful that any site selling a just released album in any downloadable format, for one dollar and twenty six cents is providing you with a legal copy.
