Shaffer
- Sep 7, 2013
Anyway, what I find most noticeable about the ECC31 is the bass. It is almost as if a subwoofer has been added to my headphones! WoW!
...this got my attention.
It is important to remember that rankings are based on very subjective and personal opinions. Everyone has different ears and different gear. A tube that sounds great to one person may well sound just OK to another.
So my advice is not to take any one person's rankings too seriously. After all, my ears and gear, my likes and dislikes, may very well be different than yours. In the end, the only way to learn which tubes are your favorites is to try them all! lol. Or at least, as many as your budget will allow. And then we hope that you will post your "rankings" here.
Cheers
Great news! While the picture was lousy, it sure looked like a Mullard. Can you make out the production code? The pre-1955 code on mine is "1029.1 1MV", where "1029" seems to indicate ECC31 and the remaining digits likely indicate factory, date and perhaps batch, but I have no idea how to go about deciphering this code. And after 1955, Mullard adopted the Philips codes, with EM (ECC31) plus a numerical change code on the first line, and on the second line, B (Blackburn) plus year and month.
And with a little bit of luck, it would be great if your second tube is of similar vintage. While I have no idea how an early 1940s ECC31 might compare to one from the mid 1950s, it is likely that they would sound somewhat different....
To the best of my knowledge, the only difference between the ECC31 and ECC32 is below the bottom mica spacer. On the ECC31, the two cathodes are tied together with a small metal strap. However, as I don't have an ECC32 to closely compare, I can't be positive.....
Another plus with these Sylvania/Philips tubes are that they are very easy to listen to. There is a sweetness to the sound. The Chatham 6AS7G bring out more detail but less punch in the bass, BUT, they are somehow tiring to listen to.
So if you don't want to spend the big bucks on the GEC A1834 (which I have not heard yet), and can't find the Chathams, by all means try a pair of the Sylvanias. You should be able to pick up a pair for $25 or less.
I tried them with different headphones and my speakers, the Sylvanias are certainly a bassy tube, more bass weight, good low end extension and full sounding bass. This to me sounded very good with the (to my ears ever so slightly bright) Beyerdynamic T1. The combo was okay with my AKG K7XX and filled the room with bass presence when using my speakers.
Soundstage is nice, pretty big, mainly very wide. To me it sounds like the C3gs bring out a lot of the details but the Sylvanias do not convey all of this detail like the GECs do. To me the GECs are in a league of their own.
All in all the Sylvania 6080WC is quite a good tube. This might not be for you if details are high on your list of priorities (although the C3gs do compensate for that somewhat) but if you like a smoother, softer, slightly bass heavy presentation with a good soundstage this just might be a good, not too expensive option.
(Damn... I got the GECs but still have the tube rolling virus...)
yes the sylvania/philips are easy to listen too, this is what i meant with smoother i think If you like the sound of the Chatham, try the GECs, similar sound signature but not at all tiring!
Will get back to you guys on the Philips 6080WA i'm trying now...
Hi LR...mordy was referring to the Chatham 6AS7G, not the GEC - hope this clears things for you!
The revised list as per gibosi's findings would be:
Tier 1.
1. GEC 6AS7G, A1834, CV2523 Straight and Curved Brown Base
2. Western Electric 421A, Chatham/Tung Sol 5998, 2399, 421A
Tier 2.
1. Bendix 6080WB with slotted graphite cross columns, GEC 6080, Mullard (Philips) 6080WA
Tier 3.
1. Tung Sol 7236, Sylvania 7236
2. Sylvania (PhilipsECB) 6080WC
Disclaimer; this is how I read it, if anyone would like to alter this list feel free. It would be awesome to get a consensus on a list of best sounding power tubes.
I can personally agree with the list, and i concur with gibosi that the Mullard (Philips) 6080WA sound very good, close to the GEC 6AS7G but missing just a touch of refinement. Am listening to them right now, a very fine tube, very natural and neutral sounding.
Hope this helps your understanding agnostic1er
Sorry if I misled you...the QTL is the one yet to arrive (from Moldova), so I was closely scrutinizing the (yes!) lousy picture...and the more I look at it the more I'm convinced it IS a Mullard...but very possibly a later one?
The definite one I received has the code(1 - or is that an edge?) 029.1, and (1) MAA...so an oldie. Gonna be very interesting to see what (if any!) codes are on the QTL.
I see... The QTL is still on its way from Moldova and so still a bit of a mystery...
Nice tubes there H1! I hope you're going to enjoy them I don't have the guts to try those 0,9A tubes in my MK6 because I can't get any answers from LD that it'd be safe David posted on the LD forums that CV181's are compatible but not sure if he means the new production CV181's which are completely different tubes.
Anyway, I remember the listing for the one you just received. If I hadn't won the the auction for the pair I have, my plan was to buy this one, old and in it's original box.
I was born in Moldova. Let me see if I can whisper a good word for you.
I am however beginning to wonder if the one I received is in fact such a good deal...a. Gentle shaking produces a slight noise, and b. in my haste I didn't pay too much attention to the test readings, and I believe a new tube Ia value should be closer to 9mA, rather than this tube's 5.8mA. Does this hint at a much shorter life perhaps? If so, I just might be having to return this one...(there are other NOS tubes for about the same price).
Cheers!
