mordy
- Aug 8, 2010
ThanksThank you sincerely for your reply. Literally answered at least three questions I’ve been researching all day. Appreciate it!
6N8S is the same as 6H8C and is a direct replacement for 6SN7GT.Can anyone confirm to me that 6N8S can be swapped with 6SN7 directly (without adapters)?
I've seen it mentioned on the forum. But they are not listed in the Elise specification.
I found an interesting 6SN7 GTB to buy, but I want to make sure first.
Ok, great. Thanks!6N8S is the same as 6H8C and is a direct replacement for 6SN7GT.
I believe it has to do with the serial number. However, when I bought my Elise mk2, it never came with any markings but it's from upscale audio so I know it's legit. You might wanna contact the previous ownerCurious there is any way to tell if the Elise is a MK1 or 2? Im buying a used one and it came with different tubes than the stock one so not sure how to tell
Previous owner isnt OG owner also so no dice lol. Either way I think @mordy said mk1 works fine with no problems so I guess I should just go with the cheapest one I can find?I believe it has to do with the serial number. However, when I bought my Elise mk2, it never came with any markings but it's from upscale audio so I know it's legit. You might wanna contact the previous owner
I have Elise mk1 along with Euforia mk1 and at times with certain tube combinations the Elise is my preferred listen. I'm sure there is very little difference audio wise between mk1 and 2.Previous owner isnt OG owner also so no dice lol. Either way I think @mordy said mk1 works fine with no problems so I guess I should just go with the cheapest one I can find?
Previously, the logo at the top had an oval shape, now it is a circle.Curious there is any way to tell if the Elise is a MK1 or 2? Im buying a used one and it came with different tubes than the stock one so not sure how to tell
Interesting. You meant the logo on the top right?Previously, the logo at the top had an oval shape, now it is a circle.
I have mk2 and there is logo in circle shape.
Yeah I think they made some minor upgrades just curious since there seems to be little indications between the versions even with the Echo as well. Was looking at the Echo 1 and 2.I have Elise mk1 along with Euforia mk1 and at times with certain tube combinations the Elise is my preferred listen. I'm sure there is very little difference audio wise between mk1 and 2.
The biggest difference between the mk1 and mk2 is the power supply. The power (allegedly) is cleaner in the mk2. Other than that, I can't distinguish any difference between the two. I have owned bothPrevious owner isnt OG owner also so no dice lol. Either way I think @mordy said mk1 works fine with no problems so I guess I should just go with the cheapest one I can find?
Yes, on the top.Interesting. You meant the logo on the top right?
https://www.themasterswitch.com/review-feliks-elise-mkII
This one is a MkII but has an oval shaped logo as well?
Thanks for the input. The round logo is certainly a mk ii for sure, but some mk ii reviews that I saw also still have the oval logo so it could be both I guess.Yes, on the top.
Photos and video reviews of earlier models had oval shape. Not sure, maybe it's possible that the first mk2 also has an oval logo. My unit, 2 months old, has already a round logo.
