Suuup
- Jun 14, 2015
See one 841 tube pictured on his site is branded: "MazdaRadio"
Yea, I want a pair of those. They're really pretty. I can only imagine how wonderful the sound must be.
Here is one for UT...female voice fan:
JV, the 841 is a triode, meaning we'd need 4 of them. Furthermore, it requires 7.5V heating, and it draws 1.2A pr tube. This would be a crazy DIY project. I'm salivating over here.
Now I want to make my own amp. Why must you do this to me JV? I'm going further and further down the rabbit hole. I must thank you though, I'm sitting here with a smile on my face, dreaming of making my own amp.
Nearly half way into the song and there's no singing. All I see are beautiful ladies... ah now the singing starts.
Omg the left channel cut off again .....no light
This is bad...may have a faulty tube. Any explanation on why this would happen? I'm into my 10th songs.
Carefully check your PS connections....
Connections fine...I swap sides and the same problem tube didn't light up while the other light up. Replace with another RVC and it works fine. More sandpaper maybe.
Hmmmm...yes, rough up that outer edge...but it is not sounding positive. If it changes sides...
But do try polishing up those paddles...
I had one of my original RVC's go dead, after I dropped it a short distance
Nope didn't drop mine. Handle with extreme care. After more sanding still the same. Replace with one of my RVC and it light up nicely, so clearly it's not the connection. I'll be contacting Mr. Da Vinci and hope he has replacement for me.
