KinGensai
I see what you're talking about. I'm dropping the response around the 200Hz mark by 2dB on the MSE to bring out the mids in the mix, so I get that.I last heard the Variations 1.5 years ago, so memory is vague. But funnily enough, I didn't particularly liked it either. I would say that I'm midbass sensitive in the sense that i am sensitive not just to too much of it (overly boomy music makes me anxious), but also sensitive to too little of it (too little makes the bass punch lack meat). I think that for me, my acceptable midbass range is much narrower than most people. It has to be within a perfect range, not too little and not too much. And I would say MMK2 is within that range, albeit on the lower end, while Variations has too much dip (it glides well but ends lower than the lower mids, which is a no-no for me). MSE is a little over that range, while GM is tastefully on the higher end of that range (from memory). I think it's also because the GM's subbass elevation is so high that is masks the midbass and balances it. The Diva's max-bass setting shelf is actually closer to my bass preference, but unfortunately the Diva's bass quality is just not refined. The Elysian X's bass glide is another example of my preference!
I think if you go to HBB's squiglink and compare GM, Elysian X, and MMK3, you'll see that the bass glide shape of the GM and Elysian X is similar, but the GM's is elevated in a balanced way from midbass all the way to subbass. By contrast, the MMK3 doesn't follow that shape. It's subbass is roughly similar to Elysian X, but midbass gets abit too much, ruining the ratio. The odd one out for me would be the Z1R. I think its bass presentation is spectacular, despite looking more midbass focused. Yet I hear the subbass extend all the way. Graphs probably don't tell everything.
I hear you on FR graphs not showing the whole picture. The MSE has become so addicting to me due to the great infrasonic rumbling it generates, FR graphs just don't show that. Unlike some more zealous graph readers out in the interwebs, I'll reserve judgement on IEMs that graph weird until I get ears on it, sometimes there's more to the story.
Yeah, that 8k peak is intentional (I think?), but I still dropped that cause top hats and cymbal hits were threatening to ring unpleasantly.Yeah the universal for MSE/GM fits me like a custom, but when buying my GM i wanted to customize my faceplates with my signature on it, so figured why not just go full CIEM since my signature on the faceplate is gonna tank the resale value anyways. Also, I found GM's 8khz a little sharp (like MSE's), so I think CIEM's slightly deeper fit will hopefully smoothen the treble just enough for me.
