Dobrescu George
Reviewer: AudiophileHeaven
Just got some new IE800's of Ebay from someone in the UK (I'm in the UK). They came in a sealed box and I can't find any obvious build quality issues, ie issues I've seen from photos on the web etc.
However, I'm not used to using ultra high end IEM's and I'm not fully sure about the sound. I've been using UE Triple fi 10's for over 5 years so have got very accustomed to their sound (paired with Sony NWZ X1060B X). I've also just changed to FiiO X7 with the IE800's.
On the same volume setting, the IE800's are notably quieter - is this right ?
The IE800''s have a 'cleaner' but less 'weighty' sound with better instrument separation. There seems to be more general colouration on the Triple fi's, which is I guess why I liked them in the first place, as when I first got them they sounded far better than my previous earphones (Sony, that cost around £50).
My problem may be that I'm so used to the Triple fi's sound, it may be a case of me needing to 'get used' to the IE800's, or is it more that the IE800's are simply not real IE800's !
Thanks.
Ie800 should have a world of more treble compared to tfi.
But even that might be relative to how much treble you hear, and how you interpret them.
Some fakes sound extremely close to originals, but as always you will be advised to always buy from trustable sellers.
Does the verification on Sennheiser work?
