ujamerstand
- Oct 18, 2009
That does not look like an exstata. "Purple Haze", is that the name of the commercial electrostatic amplifier by Cavalli Audio?
If anyone is still needs 6s4a, I have another batch - just have to sort and test, along with a bunch of other triodes.
Oh, and a little pron, just for good measure.
question #2: for the star ground, should this also connect the A/C ground wire/chassis?
I need an opinion sort of thing again. This time is about the way to mount R31~R34 for the hybrid version. I see three choices here:
To all the hybrid builders out there, how are you mounting your R31-R34?
I go vertical on the resistors, then angle the leads down. Opposite of your #2 sketch. I also use a round set of needle nose pliers to hold the lead near the resistor to keep from cracking it.
Too late. I've tombstoned them yesterday.
