- Oct 14, 2013
Here is what you need...
Yes, but that will have to be going through from Mainboard to the card , and not straight from the Power Supply unit , isn’t it
Bit old, both this thread and my own add-in soundcard, but I'd like to ask whether this card would sound better than my current Xonas STX ( 1 ).
I'm torn between modding the Xonar card with caps and new opamps or get the NUaudio. the NU Audio might simply have a tad better DAC, which is non replaceble ( socket ) on both card, right?/QUOTE]
Have you tried the Uni drivers for the Xonar - see http://maxedtech.com/asus-xonar-unified-drivers/. I found the drivers gave a better sound when used with my retired dsx. The Nu Audio was a big improvement especially when used with Foobar upsampled to DSD256. The DACs are probably on par (maybe a slight edge to the newer AKM DAC) but the Nu Audio power regulation is superior to the ASUS giving better S/N and less jitter..
That aside, the Xonas Stx 1 was released 2009 and would be getting a bit tired by now. The EVGA card (the DAC is fixed) would be a noticeable improvement especially if you update the output and headphone op amps with Burson VSi Dual X 2. These can be ordered direct for US$69 (https://www.bursonaudio.com/products/supreme-sound-opamp-v5i/) or wait until they are relisted in Massdrop (https://drop.com/buy/burson-audio-v5i-opamps)
They're designed for more than gaming, as you might find watching movies more fun when playing around with the Surround or Compressor (to adjust volume floor and ceiling). Similarly, you might just want to use the quick EQ rather than the 10-band Equalizer for a fast adjustment.Hi Lee
Thank you for taking the time to reply. Will I lose out on the Nahimic features when using the card for music playback, or are these features designed for gaming.
Thanks
Thanks for the reply. It seems the Nu Audio card is a more sophisticated dac/amp than the Mojo.Just got one in house and i have to be honest to my ears it is much more articulate and detailed than my chord mojo
